need 14 pin connector help
I am helping a friend install his 76 930 engine in a new to him 76 930 chassis. The 14 pin connectors on both the chassis and the engine have been modified with lots of splices, some with mismatched colors or gauges. We are using the color foldout wiring diagrams to guide our work , but need help as to which color wire and pin go to each hole in the connector halves. Any help will be greatly appreciated!
Old 03-24-2021, 04:43 PM
David's Avatar
I made some 14 pin drawings several years ago you should find with a search.
Here: EFI conversion
Old 03-27-2021, 05:09 AM
Engine Harness Wiring (14 Pin Connector)
6 wires off main harness terminate on engine sensors and switches
Pin 9 - Green / White
Oil idiot light switch – Right rear of engine on top of scavenger tube and check valve – (911-606-230-00-M85)
Pin 4 – Green / Red
Oil pressure sender - Right front of engine above chain box next to fan perch - (911-606-111-01)
Pin 9 – White /Green
Oil temp. Gauge sensor - Right Front just below and to the left of the oil pressure sender - (930-606-112-00)
Pin 10 – Red-Black / Yellow
Thermo Time Switch - Left timing chain cover Thermo time Switch - (911-617-117-00-M100)
78 930 Engine 14 Pin Connector
Pin 1 – Yellow - Starter
Pin 2 – Red / White - CDI Box (In 6 Pin CDI Connector)
Pin 3 – Green / Black – Oil Temp Gage
Pin 4 – Green / Red – Oil Pressure Transducer
Pin 5 – Yellow / Green – Back Up Lites (not on engine)
Pin 6 – Grey / Brown – Back up Lites (not on engine)
Pin 7 – White - Over Boost Switch
Pin 8 – Brown / Black – Air Flow Meter Switch
Pin 9 – Green / White – Oil Pressure Switch
Pin 10 – Red-Black / Yellow – Thermo Valve
Pin 11 – Blue - Voltage Regulator (not on engine)
Pin 12 – Black / White CDI Box (In 6 Pin CDI Connector)
Pin 13 – Brown / White – Charge Pressure Sensor
Pin 14 – Red – Alternator
Good luck sir
Helio Lopes
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 03-29-2021, 12:47 PM
I downloaded this diagram from somewhere on PP a while ago.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-29-2021, 02:47 PM
Thank you all!
Old 03-29-2021, 04:27 PM
