need 14 pin connector help
I am helping a friend install his 76 930 engine in a new to him 76 930 chassis. The 14 pin connectors on both the chassis and the engine have been modified with lots of splices, some with mismatched colors or gauges. We are using the color foldout wiring diagrams to guide our work , but need help as to which color wire and pin go to each hole in the connector halves. Any help will be greatly appreciated!
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 03-27-2021 at 05:13 AM.. |
Engine Harness Wiring (14 Pin Connector)
6 wires off main harness terminate on engine sensors and switches Pin 9 - Green / White Oil idiot light switch – Right rear of engine on top of scavenger tube and check valve – (911-606-230-00-M85) Pin 4 – Green / Red Oil pressure sender - Right front of engine above chain box next to fan perch - (911-606-111-01) Pin 9 – White /Green Oil temp. Gauge sensor - Right Front just below and to the left of the oil pressure sender - (930-606-112-00) Pin 10 – Red-Black / Yellow Thermo Time Switch - Left timing chain cover Thermo time Switch - (911-617-117-00-M100) 78 930 Engine 14 Pin Connector Pin 1 – Yellow - Starter Pin 2 – Red / White - CDI Box (In 6 Pin CDI Connector) Pin 3 – Green / Black – Oil Temp Gage Pin 4 – Green / Red – Oil Pressure Transducer Pin 5 – Yellow / Green – Back Up Lites (not on engine) Pin 6 – Grey / Brown – Back up Lites (not on engine) Pin 7 – White - Over Boost Switch Pin 8 – Brown / Black – Air Flow Meter Switch Pin 9 – Green / White – Oil Pressure Switch Pin 10 – Red-Black / Yellow – Thermo Valve Pin 11 – Blue - Voltage Regulator (not on engine) Pin 12 – Black / White CDI Box (In 6 Pin CDI Connector) Pin 13 – Brown / White – Charge Pressure Sensor Pin 14 – Red – Alternator Good luck sir Helio Lopes
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Thank you all!
