Turbofrog
Has anyone used BIG truck air filter on their 930?
https://www.dieselequipmentinc.com/products/b085011
That would clear all the air needed with little pressure drop but its chunky and a bit heavier than your normal cone dust feeder. I now have a 4" opening from wheel well that would fit one of these bad boys nicely.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
That looks just like the filter in my Turbo Diesel Motorhome. The diesel is pulling 30lbs of boost most of the time so maybe three times the flow. Would the excess capacity affect the performance?
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
Turbofrog
They should flow well because of the size but not sure how power level affects the flow, thats why I asked for experience. I just ordered one...
An air filter can act as a restriction, and by going to a much larger one you essentially remove that restriction thus optimizing that part of the process. Once the restriction is negligible, adding excess capacity produces no more benefit except a longer filter-replacement interval. However it can cause problems such as fitment issues or it may cost more, etc.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Crotchety Old Bastard
Dyno shows no difference between smaller K&N cone filter and no filter at all when tested up to 400whp.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Turbofrog
I already have backpressure raising even with dual headerWGs and zork so Im trying to optimize intake restrictions and still keeping the air clean which is a bit harder with KN.
So this is going in the wheel well area above the tire?
Derrick |
Turbofrog
No, just the 4” alu pipes go there and this goes behind the IC or right at the 4” opening if there is space in some tilt angle facing forward.
