Looking to delete Lamda from '87 930 to install into '74
I'm looking to install an '87 930 engine into a '74 chassis and don't want to add the Lambda system. I don't have the chassis harness or Control units for any of the Lambda.
Can I just remove the enrichment harness bits and remove the freq. valve. Or do I need to change out the Fuel dist and WR ?
Old 05-24-2021, 12:07 PM
Pretty sure that you won’t need to worry about your fuel distributor. Not sure about the WUR
I’m sure someone will chime in soon with a more definitive answer.
I have a 81 so, no Lambda. LMK if you need any part #s or pix
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 05-24-2021, 12:37 PM
TurboKraft's Avatar
You'll need to modify the FD like a -1985 version. Send off to CIS Flow Tech and they can convert it (and clean, test, balance flow).
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 05-24-2021, 06:33 PM
Certified User
billjam's Avatar
A few years ago, Tremelune uploaded a bunch of files I created to somewhere on the internet for us all to use.
One of those files is a wiring diagram for an '86 930 which shows all the devices and wiring that can be removed to effectively delete all the emission controls.
Click on the link "1986 930 engine wiring diagram, emissions delete (PDF)" in this thread from 2015.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 05-25-2021, 04:51 AM
