Reverse switch pin issue
This is on my 78 930 outlaw
Has anyone had this issue? As you know, the pin needs to slide out to engage the reverse light switch. Mine doesn't move. Neutral, all forward gears and reverse gear have the pin in the same postion - always out. So the reverse lights are always on.
Obviously an internal issue (maybe). But pull the engine and trans just to get the back-up lights to work?!!!!! Has to be another way
Any one have ideas on this
thanks,
Mark
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 08-05-2021, 05:15 PM
David's Avatar
I can’t offer any help on this but since you’re on the subject, can the reverse switch be unscrewed and replaced or is there risk of the pin popping out? How about trans fluid level?
Old 08-05-2021, 07:31 PM
I replaced my switch due to broken terminals and had no issues with the pin. I didn’t know to even be concerned about it. But it sounds like the OP has his out already and has eyes on the pin and it’s not moving. Sounds internal. I’d run a toggle switch somewhere to turn them off/on before I’d drop the engine over this, and then address it next time you do a drop for a bigger reason.
Ken
1986 930 2016 R1200RS
Old 08-06-2021, 06:20 AM
The pin just slides in or out. It is completely removable. If it comes out when you remove the switch - no issue - just slides back in.
Old 08-06-2021, 06:59 AM
my pin is completely loose. Not hung up. Re-adjusted the shift coupling to see if reverse was not full engaged. No changes.
Thought of putting in a toggle switch under the dash - but I hate temp fixes
Old 08-06-2021, 07:01 AM
Bucketlist's Avatar
This needed repair is on my list now that I can finally get the car up in the air.....
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 08-07-2021, 03:52 AM
xbmwguy's Avatar
Steve. I hope you have a mirrored garage floor !
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 08-09-2021, 07:18 AM
Work in Progress
Rich76_911s's Avatar
Can't the pins get worn down and become too short to create the needed contact? I recall some guys in the 911 forum used a drill bit in the 915 transmission as a replacement. But I'm not sure if the same bit would work in the 930 transmissions.
My backup lights don't operate either and I couldn't find a replacement pin anywhere. Seems like the part is NLA.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 08-09-2021, 07:43 AM
I have found the pin, over time wears and I have found some slightly shorter than others. I do not recall what the length should be. We did discover that changing out the pin itself resolved the problem.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 08-09-2021, 11:29 AM
Bucketlist's Avatar
I knew I was missing something.
Old 08-10-2021, 03:47 AM
