throttle respons on turbo engine
just a curious thought what is it that affect the most at our cars slow free rev throttle respons?
my car has LW flywheel, ported heads, cams and frankencis so i can adjust the fuel good, but it has that boring slow free rev feeling.
i am guessing the low CR and timing is one thing.
also curious how much difference in spool up is a shorter exhaust manifold and a modern twinscroll turbo make?
Old 09-16-2021, 03:17 AM
A modern turbo will transform the throttle response..drastically.
Old 09-16-2021, 05:06 AM
Originally Posted by Porter2 View Post
Turbo lag is the hesitation or slowed throttle response you experience when driving a turbocharged vehicle, before the turbocharger starts to kick in and provide extra power to your engine.
yes i know
I wanted to discuss the technically complicated parts of cis turbo porsches that makes just this engines so remarkable slow free reving
Old 09-16-2021, 06:03 AM
Crotchety Old Bastard
RarlyL8's Avatar
The air meter plate is not the fastest reacting when you compare to something like ITb's. Removing back pressure will improve throttle response, such as replacing the OE muffler with a free flowing muffler or Zork tube.
Old 09-16-2021, 06:09 AM
I have a C2 turbo with CIS and recently a modded fuel head.
My Turbo is a RUF K29 (Pig).
My modification list is linked below.
My C2 revs so fast both free rev and under boost - I have had to set my soft touch rev control below
stock limit. The car Revs so fast it will fly past redline before you know it......I hit the soft touch rev limiter so easy and it sounds like gunfire and sets the Cops off.
Forced to Deal with This
Old 09-16-2021, 06:25 AM
Porsche 935's Avatar
Many things can help the engine rev faster. Light weight engine components, lighter car, shorter gears, higher compression ( more power not under boost) , newer style turbos. You get the idea. Even though I have longer gears, I have all the other items I listed, probably why I can jump from 70-100 in less than 2.5 seconds. Not bad for 45 year old car.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 09-16-2021, 07:26 AM
David's Avatar
My 930 is set up like the one above with similar performance. Checking my EFI data logs, it revs from 3000 to 6500 rpm in the stock 4 speed 1st gear in 1 second. So that's about 25-53 mph in a second.
Old 09-16-2021, 11:15 AM
I suspect he’s asking about revving the engine in neutral, and asking why it’s not snappier. And for that I’d suggest that the CIS trap door air meter and the heavy flywheel are probably the main contributors. The turbo can’t matter at this no load condition.
Turbokraft had posted an IG of one of their EFI builds and it had insane throttle response. Sounded like a motorcycle. Clearly they addressed whatever the reasons the stock ones are a bit ponderous.
Ken
1986 930 2016 R1200RS
Old 09-16-2021, 11:55 AM
AskewRSR's Avatar
6 throttles will solve your issue. ITB's. They give the Sport Bike Throttle response..... But get out your checkbook.....
1965 911 Vin 1249 Slate Grey
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 09-16-2021, 01:21 PM
I think it may be these cars need the equivalent of an accelerator pump that dumps some fuel down the the intake when the throttle is mashed. Like 4 barrels have.
My car is EFI and I can adjust the acceleration fueling to add in extra fuel for up to 2 seconds when the pedal moves above a certain velocity or when the manifold air pressure changes above a defined threshold. My engine revs pretty quickly in neutral (or anytime, for that matter)
Maybe there is a way to accomplish something like this with the CIS system...
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 09-16-2021, 04:01 PM
Turbo engines are NA engines when reeving to red-line in neutral. A map log should read more or less zero on pressure readings from back-pressure / boost when reeving in neutral on a turbo engine unless the muffler or intercooler is filled with dirt or intentionally mismatched. Throttle response is when the throttle is let open in neutral (or clutch engaged). All other scenarios when gears are engaged and driving is no longer throttle response.
For quicker and fast throttle response these are the main factors:
1) Piston travel (stroke) - keep as short as possible
2) Air volume between throttle(s) and inlet valve - keep as low as possible
3) Weight from rotating parts linked to the crank, i.e. crank, flywheel, clutch, rods, pistons, rockers, valves, fan, alternator, pulleys, etc. etc. - keep all rotating mass as low as possible
4) Compression, static and dynamic (cam profiles) - keep as high as possible
5) Ignition timing - keep as close to MBT (Minimal advance for Best Torque)
6) Fueling, among others correct acceleration enrichment etc...
The turbo spinning with no inlet resistance in neutral have no noticeable change or impact on throttle response
Old 09-16-2021, 05:21 PM
RarlyL8's Avatar
Muffler will affect throttle response. If the car has a stock muffler remove it and see what happens.
Old 09-17-2021, 05:52 AM
Ingenieur
My top three are
CIS
Muffler
Flywheel
CIS is always injecting, so fuel is always burning. When you do a throttle blip, there is combustion on the way up, and on the way down.
Muffler - the back pressure, as discussed
Flywheel - heavy to begin with, and the rubber donut makes it worse.
Old 09-19-2021, 01:40 PM
T77911S's Avatar
ported heads and bigger cams can also reduce it.
cam timing is another
turbo is a biggie.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-20-2021, 07:41 AM
dos531's Avatar
It's just one of the many drawbacks of that terrible CIS system. My throttle response was drastically improved by converting to EFI.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 09-22-2021, 09:54 AM
The OP stated that he has a LW flywheel, ported heads, cams and frankencis.
What were your heads and manifold ported to ? Typically opening up your intake and heads will gain top end power but give it up on the other end. Which cams are installed ? If SC that should help some on the low end. Which exhaust and turbo ? As stated those are going to be the game changer.
A free flowing exhaust and a modern turbo transforms these cars. I’m not at all versed with FrankinCIS but perhaps there are low end gains to be had with tuning.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 09-22-2021, 03:05 PM
