1979 930 @outlaw3.4
Oil Temp Sensor for INNOVATE MTX....SOS
I am out of my wits....I searched and googled and I must say this whole project is way more frustrating then I imagined. I am half way through the 145 page manual for programming the gauges to log my fuel curve.
I have a 79 930 and am not looking to modify or change the exisiting dash mounted VDO oil temp gauge. I am looking to add a second oil temp sensor somewhere in the flow to feed my innovate MTX gauge for data logging. THe idsea oof drilling out the oil drain plug ais a non started.. I am open to ideas....please ![]() My winter projects: 1)Adaptive Motorsports Fuse Panel 2) Running 2 dedicated fused power lines to the fuel pump relays 3) Adding the 044 fuel pumps 4) Upgrading the 965 diverter valve 5)Installing the Innovate MTX AFR, Boost, RPM, Volt, Fuel Pressure and Oil Temp. ![]()
1979 930 3.4l Peter Dawe Motor, Bosch Twin Plug, Dual Bosch CDI, J&S Ignition Control, Webcam 158 , Maxed Flowtech Fuel Head, BL Adj WUR, Braided Fuel Lines, 009 Injectors, GT35R, TIAL .7with Turbosmart MBC, Fabspeed Long Neck IC, Fabspeed Headers, GT3 Style Pipe off turbo, Rennshift Short Shift, KEP Clutch Package, 8.41, Elephant Racing Suspension, Weltmeister Sway Bars, ??WHP, Innovate MTS Gauges, RPM, Switch,SplitSecondAIC 7th |
