Ingenieur
Is there a dual disk clutch setup for aircooled 930’s?
I’m talking two disks and one floating plate. Seems like the long bellhousing ‘78 and later 930 trans would be a natural for that. High torque, low pedal force, good for high RPM launch.
I think smaller diam multiplate clutch are for racing, if that’s why you’re asking it makes sense.
I think for street it’s a bad idea. Try driving a m/t 928 or 1st gen NSX or Carrera GT. They have multi plate small diam clutches, once under way everything is great but taking off is where difficulties arise. They’re reluctant to slip and small diam reduces leverage to get car going.
86 911 Turbo - K27-7006, BB 3" Dual outlet, BB IC 96 911 C2 6sp dd 88 M3 |
Chain fence eating turbo
I'd love to ditch my stage II pressure plate and only use a stock or stage I for lighter pedal pressure but still get great torque handling capability.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() |
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
I like the light clutch idea but looking on the KEP website, they look heavy.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Administrator
Pelican carries the SPEC brand and it looks like the stage 3 is a twin disk setup.
https://www.pelicanparts.com/More_Info/SPCSP043.htm?pn=SPC-SP043&bt=Y&fs=0&SVSVSI=784 But as others have stated with a higher stages comes a stiffer clutch. |
I appears the spec is a push clutch and the 76 and 930 is a pull
reagards |
i have an 8inch triple disk in my race car.
was trying to turn it around in the drive way one day and it did not like the constant clutching i had to do. started to smell it. yes great once under way but not a street driver. yes very small and light. i hate the size and weight of the 930 clutch. dont know what they were thinking on this one.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Ingenieur
Yep, there are two ways to go. Small and lightweight with quite a bit of disengagement force, or normal sized with low pedal force.
Ingenieur
Except that nobody seems to make a normal sized one.
AASCO can likely make you a setup using Tilton parts and a custom flywheel.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
I called Tilton when my 934 style clutch would no longer hold the power and they wouldn't even talk to me.
3.3 ltr, stock compression, efi, twin turbo - no intercooler. |
Tilton only deals with their Dealers and more than likely for this they would send you to Aasco
regards |
I always wondered if the 934/935 Sachs clutches for long bellhousings could be converted to a dual disc setup. If you look at the pressure plate inside the clutch, it has a long lip to push it towards the flywheel. If one were to remove that lip and thereby moving the pressure plate closer to the clutch spring, there might be enough room for another disc and an intermediate steel. The only question then would be if there is enough travel for complete disengagement.
They can be.
The only downside is it is a heavy assembly, lots of rotating mass. And it rattles and chatters in neutral or with the pedal pushed in.
Noisy dual clutches are long gone after they came up with the spring preloaded center plate, I've never saw a noisy/clattery dual disc clutch in the past 10 years or so.
It's a 914 ...
^ This. Tilton makes excellent clutches for racing. Use one on the street and you're asking for trouble. They overheat easily when getting the car rolling. Solid disks are a bit harsh too when getting the car moving in first gear. It would be an unpleasant experience overall using one on the street. The one pictured above seems to have sprung disks, possibly a better option. Last edited by stownsen914; 04-02-2022 at 04:22 PM.. |
For the more streetable domestic stuff, like the Centerforce's DYAD and the McCleod RXT, I agree they are as silent as the stock clutch with very low pedal effort.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft Last edited by TurboKraft; 04-02-2022 at 03:28 PM.. Reason: edit |
I talked to AASCO yesterday and the only Tilton clutches available are push types. Consequently, if you want a Tilton clutch, the clutch pedal will need to be changed from cable to hydraulic.
Spec has a stage 5 clutch for a 930, rated at 980 ftlbs, I am very curious about how stiff that pedal would be and how often the clutch cable would need to be adjusted/replaced and how hard that would be on throw out bearings? |
Thread Tools | |
Rate This Thread | |
