SC vs 965s Cams
We're getting to the reassembling faze on my build. Rods rebuilt arp bolts, new bearings, heads done, stock ports and intake man. Bought a gt35r and halfbay intercooler from Turbokraft, also a new waste gate. Now it's time for a cam choice. My plan was for either the SC cams or 964. TK has some other cams that I think are a reworked version of the 964 being called 965s cams. I guess my question is do the 964/965s cams have a lot of lope, this is for a street car, has never and probly will never see the track, how often on the street would I even be on the cams with the 964/964s cams. I'm thinking the SC might be a better street cams but it seems more are going with the newer profile 964. I'm not against more power, he'll that's what I want, were also doing the lightweight clutch setup and the car previously had a new set of GHL headers and a dual out muff. Famous last question, what would you do..
I have had SC cams , I now have TK 965s cams with CIS
the TK 965s cams perform better everywhere than the sc cams , even off boost Chris can quote some side by side numbers and the increase over SC cams is substantial I can pull cleanly in 3rd from 5 mph Forced to Deal with This |
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
Thanks Black_Hat, how do those cams idel in your car as compared to the SC.
more lope , read my last post in the link above
you will need to valve notch the pistons |
Crotchety Old Bastard
If you are only comparing SC to 964 the cam should follow with the turbo.
For example, if you are after street driving torque then the SC cams with K27-7200 or GT30 are a good match, for more power higher in the rev range the 964 cams mate well with K27/29 or GT35. Both SC and 964 are slide-in, set timing and go, all will need the 930 oil pump drive.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Ya, I allready have the GT35, and your right both cams drop right in. We allready have a nice set of OE SC cams modified ready to go, The 965S cams Chris sells is basicly a very slightly reworked for CIS 964 cam, it's really splitting hairs at this point, looks like about 8hp at 1k rpm higher for the 964/965S to super simplify. Then there's the quality of the cams themselves, The porsche OE being very high. All being said either way is good, I think we will use the SC cams, Smooth idel, OE porsche quality, Even Porsche used them in there Factory X33 package.
Thanks for the replies R |
Brando
I use stock fueling, msd ignition and sc cams. There are no problems with running. It runs great. My engine is a 77 3.0 as well.
Timing is 1.6-1.7 on the cams. This is correct setting. |
Thank you. I forgot to say that I am running a K27-7200, as well.
Tom, your issue may not be cam related. We set the SC cams at top of spec for max torque off boost. The 330hp factory option used these cams as well. They really wake up the engine.
There is a grind in between the two you are looking at - sometimes called Super SC, or Elgin. If you do a search you should pull up a thread where I had a similar query. These cams got a very enthusiastic response from the users. Might pay to do a search on these before making a decision. Bolt in.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
The grind is called "SC330", they are nice for a mildly modified street 930.
Metal Guru
Since the turbo is forcing air into the engine, there's a lot of latitude in selecting what turbo to use and cams aren't really going to affect that choice all that much.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Chain fence eating turbo
Anyone know the specs on the 965S cams? Curious.
I made the assumption that the turbo chosen matches the engine. On any engine the cams ports redline boost and turbo all need to work together, for a stock engine this means torque oriented cams and mild turbo. Put big cams and big turbo on a stock engine and you get a turd.
Moriarty
I'm in the reflexion process for my (euro) 930. It already has a K27-7200 and a 0,9b boost spring, K&N air filter with a new (empty) muffler.
Next step will be a better IC, a BL adjustable Wur and new cams, still wondering which ones between the SC and the 964, after reading this thread it appears to me that the SC should be the best, what do you think ? Last edited by Moriarty; 03-12-2015 at 09:18 AM.. |
3 restos WIP = psycho
There's always the 993SS cam for those who have big ports, high compression and like a top end rush.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
The difference between the SC and 964 cams is the 964 cams move the torque curve about 500rpm to the right on a dyno graph. Decide where you want peak torque and choose the cams and turbo that will accommodate.
I Think Rarly8 sums it up nicely, If I had opened up the intake man and ports and or added compression I would have done the 964/965S cams hands down, but on a stock compression, stock head and man engine i think the SC will work out quite fine. My builder has done a itb 3.4 with stock euro exhaust and SC cams and did over 500hp on a engine dyno so I don't think they will be a limitation in my setup. I just typed in all the specs for all 3 cams then my iPad froze so screw it. If anyone wants to know just look at the porsche cam grinders web sights, the specs are listed there...
-R |
