rufrob's Avatar
Speedometer quandary
Took my 81-930 out for spin for the first time in many years. The speedometer stopped working. I am getting a pulse signal from one of the brown/red wires at the speedometer.
I’ve done a lot of reading but can’t seem to find the correct answer. Should there be a pulse from both wires and what is the correct connection at the speedometer.
Some say Red, blank, Br/R signal, Br/R and Br or R, blank, BrR and BrR, Br
Never give up
Old 08-16-2022, 04:11 PM
Is everything else working, lights? Might be the electrical part of your ignition switch, try wiggling the key when driving.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-16-2022, 06:23 PM
rufrob's Avatar
Nope. Still not moving. checked all the fuses gonna see if I can swap speedometer with a buddy.
Never give up
Old 08-18-2022, 02:21 AM
Speedometer wiring connections
Originally Posted by porwolf View Post
I think you have the two brown/red speed sensor wires connected to the same terminal on the far right of your picture. In my '79SC the two speed sensor wires come out of a black sleeve together with the black/red 12V power wire. I am not absolutely sure but for my '79SC speedometer the correct wiring should be as shown here:
For comparison, my '79SC speedometer wiring:
Old 08-25-2022, 05:47 PM
rufrob's Avatar
Some parts in the speedometer failed. Got it repaired and I’m back in business trying to “test” its operating range.
Never give up
Old 09-01-2022, 09:57 PM
