Breeang's Avatar
Angry Speedometer wiring connections
OK. I removed my speedo for repairs (usual odometer malfunction). Took careful photographs to record the position of the wiring connections at the back. Sent the speedo off to be fixed but lost my phone with the photographs.
So after several attempts working from memory I have the speedo lights working, but nothing else functions ( no speedo, no odometer). Where do the wires connect at the back to have the instrument functioning properly ? I have stopped for the evening before I start using my big hammer .
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 02-16-2014, 04:34 PM
Breeang's Avatar
Forgot to mention that this is a VDO gauge from a 1977.
Old 02-16-2014, 04:36 PM
kodioneill's Avatar
red/black to 12v connection. brown/red to 31b connection. black/blue to inst. light connections.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-17-2014, 06:25 AM
irl irl is online now
irl's Avatar
Send a message via AIM to irl
found this, may help
can anyone id these loose wires behind speedo?
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 02-17-2014, 07:28 AM
irl's Avatar
this looks like a good one also.
Need guidance on troubleshooting speedometer problem...
79 SC unmolested
25 GTS
Old 02-17-2014, 07:36 AM
Breeang's Avatar
C:\Documents and Settings\brian.JMHC\My Documents\My Pictures\SPEEDO WIRES
Old 02-18-2014, 09:48 AM
Breeang's Avatar
Thanks for the input guys, but still no speedo/odometer. I have the wires as follows: moving clockwise from the left hand side as seen.
---red/blue and red/black on first connector
---no connector
---red/white on second connector
---solid brown and solid brown on third connector
---brown/red and brown/red on fourth connector
The lights are okay.
What have I got messed up here?
Old 02-18-2014, 10:16 AM
porwolf's Avatar
---no connector
I think you have the two brown/red speed sensor wires connected to the same terminal on the far right of your picture. In my '79SC the two speed sensor wires come out of a black sleeve together with the black/red 12V power wire. I am not absolutely sure but for my '79SC speedometer the correct wiring should be as shown here:
For comparison, my '79SC speedometer wiring:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-18-2014, 01:14 PM
Breeang's Avatar
It's alive !!!
Thanks to everybody, and the final push from porwolf was the clincher.
It still doesn't seem right to have a speed sensor wire piggy backed with a ground wire and then plugged in, but hey it works!! .
Old 02-19-2014, 07:02 AM
