Maximum safe constant rpm for track car
Just wondering what you guys would think a safe constant rpm would be for a stock 930?
Old 05-25-2023, 12:12 PM
Highest safe constant rpm
Old 05-25-2023, 12:13 PM
Just passing along info from another's opinion. quote "75% of redline".
Anthony @ Voitureltd Bayside WI.
Old 05-26-2023, 08:50 AM
Mick,
According to the WorkShop Manual, for my 1976 930:
Max. permissible speed 6700 rpm
Max. constant speed 6000 rpm
Governor cut-off speed 7000 +-200
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 05-26-2023, 09:58 AM
Thanks guys. I did a search and couldn’t find any info on the subject anywhere.
Old 05-26-2023, 01:45 PM
[QUOTE=356911930;12009130]Mick,
giddy up those horses. I like the info for 90% of redline better than the 75% info for a stock 930.
Old 05-26-2023, 02:56 PM
Crotchety Old Bastard
RarlyL8's Avatar
Decades ago I read a technical article about 930 drive train endurance testing done in the 70's. The stock cars were driven by a team of drivers on a large oval track at 6k RPM for thousands of miles, with the only stops being for fuel and to change the oil.
Old 05-27-2023, 06:00 AM
Ollies930's Avatar
Brian,
do you remember if that was flat out in 4th (which would exceed the top speed given for those cars by 6-8mph) or in 3rd gear. That would be some very different thermal loads for the engine.
Old 05-27-2023, 10:47 AM
RarlyL8's Avatar
4th gear, top end. I had a really hard time believing they actually did this type of testing. The purpose was for endurance racing.
Old 05-28-2023, 08:13 AM
safe's Avatar
A German car that couldn't go flat out in top gear for hours would be an embarrassment and not released for sale.
Saab (not German I know) ran stock 9000s at Talladega at full throttle for 20 days covering 100.000 km, only stopping for fuel and services.
Magnus
Old 05-28-2023, 01:17 PM
RarlyL8's Avatar
This was the same, they ran the cars wide open for a month, non stop. Over 100,000 miles. Hard to wrap my mind around that!
Old 05-28-2023, 06:36 PM
Sounds like 5500rpms for short intervals on track for 20min sessions should be no problem.
Old 06-01-2023, 01:44 PM
Alan L's Avatar
I have driven mine harder than that for 20 yrs, no mechanical issues.
I first had an EGT gauge for safety. It had a red light (as well as the temp gauge) that kept flashing after about 3 laps. I disconnected it. It was around 900 Deg C from memory.
Your oil temp is the critical indicator - along with AFR.
I recently fitted an additional cooler - knocked the temps down about 20 deg C - in to the comfortable Hwy cruising zone. Happy with that. I try to keep the AFRs between 12- 12.5. They have gone as high as 13 - but I am unhappy about that and will rectify. That would only be short term - few seconds between gear shifts. But it doesn't take long for detonation.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-01-2023, 06:13 PM
safe's Avatar
Shifting slightly (100 rpm) before the revlimiter every shift for hours is not a problem. It's put there by Porsche to be a safe and useful limit. The engine internals is probably safe for more.
Magnus
Old 06-01-2023, 08:53 PM
flat6pilot's Avatar
Keep it below 6k and you should be fine.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 06-23-2023, 01:13 PM
Interesting. Wide Open or 6K? Wouldn’t wide open be just under rev limiter?
Old 06-24-2023, 02:13 PM
My 930 is a 100% track driven car and spends most of its time at full throttle in all gears other than first. I shift between 6700 and 7000 with the occasional rev limiter bounce and the engine seems really healthy at about 64 hours now. The engine is running 964 cams and a ball bearing turbo sitting on Brian's headers, makes 460 at the wheels.
All good
Old 06-27-2023, 07:30 AM
