Fear No Rust
fourblades's Avatar
Locking a 930 transmission without special tools
This is a duplicate of a post I made in my 930 restoration thread. I made a separate post for it to make it easier for people to find in the future while searching thread titles, and because I am a post whore.
Having seen some weird approaches to locking a 930 transmission, I thought I would explain a simple approach that is described in the 930 shop manual and that worked well for me once I figured it out. I think this only works for the 4 speed 930 transmission due to how its reverse gear and gear shafts are arranged.
No Porsche special tools are needed for this approach.
The shop manual does not waste words, so you need to read this carefully and study the picture to understand what it is saying. You can remove and later retorque the shaft nuts (which have a lot of oomph pounds on them) by locking the two shafts together using this approach. You do this by putting the reverse idler gear (gear II in shop manual lingo) onto its own shaft, putting that shaft into the hole where it lives, and sliding the reverse gear down so it engages both shaft gears. This puts the transmission into reverse. Putting the transmission into fourth gear at the same time locks the shafts together. Having the cover off allows you to engage both gears at once.
The shaft where the reverse gear lives is pressed into the transmission end cover. To use it as described by the manual you need to remove it from the cover. To get it out, you need to heat the cover around the shaft (don’t heat the shaft) using a propane or Mapp torch to 120C (more or less) and tap it out. The shaft is 15mm in diameter and has a smaller section that fits into the transmission body, so using a similar size shaft might work, but it might not seat down enough to keep the transmission gears locked. I did not have any other 15mm shafts available to try so I removed the reverse shaft.
Then tap it out with a hammer and a brass drift. It does not take a lot of force to get it out.
Slide the removed shaft down into its corresponding hole. Make sure to put the end that came out of the cover up, so the shaft fits down perfectly in the hole.
Move the reverse gear engagement arm to the side and slide the reverse gear down onto the shaft. A little wiggling might be needed to get all three gears to engage.
Next you can shift the transmission into fourth gear by rotating the shift selector rod fully clockwise and pushing down on it. Now the transmission is in reverse and fourth at the same time, locking the shafts in place. The shaft nuts are staked to a groove in the shafts. This must be pried up using a screwdriver or punch.
I used washers and 8-inch wood screws driven down into my thick wood workbench to keep the transmission from moving as I applied torque to the nuts. This was a quick and easy way to secure it for the 5 minutes needed to remove and later retorque the nuts.
Once secured, the nuts can be easily removed and replaced later using the same approach. There is no need to hold the reverse gear down while applying torque.
Once you have completed your transmission rebuild, and retorqued the shaft nuts, the reverse gear shaft can be tapped back into the transmission cover. Remember to heat the area of the cover around the hole for the shaft. Make sure to orient the shaft the correct way or your cover will not close again. The outside end of my shaft is rusted making this easy to determine. Remember to reassemble the reverse gear engagement arm and reverse gear appropriately before closing the cover.
Other pearls of wisdom from the shop manual are to use Loctite and Loctite primer on the threads when replacing the shaft nuts. I guess just staking the nuts is not enough. Note that both shaft nuts are available from our host here in 2023. It seems the larger nut was not available anywhere for some years.
Hope this helps someone out down the road.
John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html
Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937
Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106
Old 09-10-2023, 06:04 AM
MikeD930's Avatar
I have regeared/rebuilt my 930 gearbox. There is no need to remove the reverse gear shaft. I held the reverse gear in place (other side of gears for removing and same side as you showed for installing) by hand for removing and installing the shaft nuts.
Plus working on a gearbox would be much easier when placed on an engine stand with a yoke.
MikeD '87 930
Old 09-14-2023, 03:07 AM
Fear No Rust
fourblades's Avatar
My reverse gear would not stay put while torquing the nuts back on without the reverse shaft. Using the shaft allows you to use both hands to apply the 150 ft lbs of torque needed. If you could hold the reverse gear place with one hand while torquing the larger nut to 150 pounds then I am impressed.
Yes, I could have gotten my engine stand down from my attic to do this. If it had turned out that I needed to rebuild the transmission after inspecting it, then I would have done that.
John
Old 09-17-2023, 03:52 PM
I use a small flat piece of aluminum and choke it between the two shaft gears to torque the two nuts, easy and fast.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 09-17-2023, 09:11 PM
MikeD930's Avatar
John
Yeah...I applied about 75 lb force on a long torque wrench while holding the reverse gear in place. I suppose that would not be possible if I need to see a readout but mine is a type that clicks once its torque setting is reached.
Great idea!!
MikeD '87 930
Old 09-18-2023, 02:27 PM
Thank you for this. I will be going into mine next year to replace 2nd and 3rd synchros.
Old 09-19-2023, 06:16 AM
