R Gruppe#756
turbo trans gurus need help FOUND ….
does anyone have a second gear needle bearing race like the one pictured
or part number I need one FOUND PART thanks ![]()
R Gruppe #756 Last edited by metshaper; 10-13-2023 at 04:01 PM.. |
Thats a shifter sleeve I think. I stand to be corrected.
EXPENSIVE. You will need to order thru the usual trans part suppliers. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
gearhead
Get the measurements and pm me. I might have one.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
R Gruppe#756
found one thanks…
R Gruppe #756 |
