belstein front strut rebuilt question??
Hi guys .
got all the bushings and seals to rebuilt my front struts .
have a few questions . removed the top cap and there is pink Grease is that the way it came from factory?
should one of the bearing be on top and the other 4 inches down?
thanks guys .
Old 11-19-2023, 03:50 PM
Alan L's Avatar
Yes, they are spaced apart. It is not rocket science to mm precision, but you are trying to support the inner rod at both ends.
Prob pay to measure what you have for spacing and replicate. I did do a write up on this forum a couple of yrs ago when I did mine. getting the old ones out was the trick.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-25-2023, 12:40 AM
David's Avatar
Might help to ask in the 911 tech forum if you need more info. A bunch of folks in Austin did theirs a year or two back but I didn't get any pictures of the tool or method.
Old 12-21-2023, 11:25 AM
Alan L's Avatar
I posted pics and the tools I made.
Getting the old bushes out is the trick. I made up a bunch of bits.
Alan
Old 12-21-2023, 09:57 PM
