Scout012's Avatar
CIS Brass fuel inlet Hollow bolt FILTER
WHERE can I find these??????? tiny removable plastic fuel filter screen in the brass fuel inlet fitting on some fuel heads
there are barely any references to them and I am wondering if i should just remove them. mine are bent up from prior removal (not me of course) and two were stacked in one fuel line bending the filter and destroying it.
Any help appreciated.
The final Picture is one off of my CIS bolt.
(1980 930 stock CIS)
KEN Euro '80 930
Old 02-18-2014, 12:24 PM
My fuel head didn't have one of those originally and when I got my fuel head back from CIS Flowtech from being modified and rebuilt it had one inside a new brass fitting.
That's a really small fine screen filter and it looked like it could impede flow at full throttle and lean out the motor under full boost so I pulled it out of there with needle nose pliers and tossed it.
You don't need it if you have a 930 Mahle fuel filter next to the accumulator. The Mahle filter has a finer micron element thats huge compared to that little tiny screen filter
You could probably get one from Larry at CIS Flowtech in Alabama.
Old 02-18-2014, 02:37 PM
proffighter's Avatar
check a Mikuni carburetor dealer (motorcycle), looks similar to me like some of the filter in the in-line of the carbs sometimes have. Diameter is maybe 5mm
Roland
930 Turbo '81 Too many modifications to list
Old 02-18-2014, 03:44 PM
Housemarkee's Avatar
old thread but...
today I ran into the problem that I broke some of the brass inlet filter in the CIS fuel head.
If anybody interested in rebuild kits for CIS Fuelheads/WUR or other spareparts...
check the webpage of these german specialist.
Quick response, how to manuals and really good service (no I´m not a sponsor)
https://www.missingparts.de/products/feinfilter-auslassfilter-fur-bosch-k-jetronic-mengenteiler-fine-filter-for-bosch-k-jetronic-fuel-distributor
Old 11-22-2023, 05:04 AM
Alan L's Avatar
As J Fairman posted, they do restrict fuel flow. If you are fairly stock and not short of fuel, fair enough. If you are hunting for more fuel, ditch it. It was one of the biggest improvements when I actually discovered the thing in the FD.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-25-2023, 12:28 AM
