Alan L's Avatar
easy cam timing tip
Well, for the 1-3 side anyway.
Just reassembling my engine after chasing a gremlin that I never really found - oil in #1 cylinder. So the outcome is uncertain. But I did stumble on a simple cam timing method.
I have only pulled the 1-3 side apart, so using the cam timing on 4-6 side to set #1Inlet.
I was looking for 1.75mm. So I set the engine to #1 TDC firing. I had all the rockers installed - but the valves backed right off (except #1 I which was at 0.1mm). I set my dial gauge on the #1 I rocker then rotated the engine half turn to #4TDC. This is the point the #1I should be open to my valve setting. I had the two drive bolts for the scavenge pump in the end of the cam. I just rotated those in the right direction until the dial gauge moved to my timing number - 1.75mm. It happened the cam was happy to sit there. I had removed the lock pin on the cam wheels and had the bolt finger tight so the wheels could rotate without moving the engine. Pulled the bolt - inserted the lock pin and cracked some torque on the bolt. Rotated evrything one more time and the timing mark came up exactly on what I had set. A one shot set at the timing.
Unfortunately it won't work for 4-6 as no drive pins in the cam end.
But dead simple, and every bit helps right?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-19-2024, 07:36 PM
Chain fence eating turbo
Great idea
Old 02-20-2024, 09:05 AM
