Originally Posted by Dieter9 View Post
Hi there !
Thank you, i have not messed with compression or cams .. all original us model 3.2 engine spec .
Boost about 7-8 psi .
Drives like a dream and turbo noise is adictive
If you have not messed around with C/R then it’ll be 9.5:1. Safe for 10psi (intercooled).
Old 02-06-2025, 10:50 AM
Could be yes, but dont want to over do it .
Its very quick as is ..
But, if i ever wanna go further its a higher psi spring away 😉
Old 02-06-2025, 11:05 AM
Bucketlist's Avatar
Here is an old chart I had in my file. Porsche built their early turbos with 6.5:1 on CIS. Many have pushed that successfully to 8.5:1 with efi.
9.5:1 at 10psi shows 16:1 Effective Compression Ratio.
Good luck!
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 02-08-2025, 02:20 AM
Meaning ? 10psi not so safe as mentioned ..
Old 02-16-2025, 02:18 AM
Bucketlist's Avatar
Boom!
Old 02-17-2025, 02:34 AM
Turbonut
Raceboy's Avatar
It is safe when considering things like turbine housing (which affects MAP/EBP ratio which itself is directly related to sensitivity to knock), how one tunes ignition table etc. If you are using factory Motronic with its advance table then you can be quite sure you get knock.
Have fuel and ignition under control and enjoy. Turbocharging is not for experimenting, better to know what to do but it is very rewarding.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 02-26-2025, 10:37 AM
New boost gauge, where the (Broken) clock was 😉
Old 03-04-2025, 12:21 PM
Brando
quattrorunner's Avatar
Jazzy
Turbo powa!
1977 911s. it's cool
Old 03-04-2025, 12:25 PM
What did your project run you in parts? I have been looking into the Promotive Stage 1 kit.
Great job on your project.
Foster
Foster
Monroe, Ga
1984 911 Carrera Targa
Old 03-12-2025, 04:16 AM
Foster
That would be about 5k !
Thank you !
Old 03-12-2025, 07:08 AM
Added cooling with spal pulling fans ;
Video :
https://youtu.be/kiBjlYpfRHI?si=eswlWANSCf1a70PT
Old 06-01-2025, 12:55 AM
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 06-03-2025, 03:04 AM
Originally Posted by mikedsilva View Post
Thx Mike !
Old 06-03-2025, 03:45 AM
New Wheels coming up
Old 06-12-2025, 12:14 PM
Old 06-28-2025, 11:44 PM
MikeD930's Avatar
Dieter9,
Good job adding a turbo along with VEMS and those are nice looking wheels!
Are you still maintaining contact with Peep? If yes, can you find out if all is well with him? It seems he dropped off the planet since he has not responded to my emails for over a month. I ordered and paid for a full optioned VEMS kit including complete harness (not a PNP) from Peep 3 months ago. So, I'm kind of worried what happened to him.
MikeD '87 930
Old 06-29-2025, 05:28 AM
Originally Posted by MikeD930 View Post
Dieter9,
Thx man !
Regarding Peep.. @raceboy ..no i have had not been able to get a answer from him either.
Me too asked him of he's ok .. but no answer .
Did he send your Vems kit?
Old 06-29-2025, 11:56 AM
MikeD930's Avatar
Thx man !
No I have not received it yet. A month ago Peep said he was half way done with the harness and that was the last I heard from him. Please let me know once you hear back from him and I'll do the same here.
MikeD '87 930
Old 06-29-2025, 04:15 PM
MikeD930's Avatar
I got an email from Peep. All is well with Peep...he got really busy with life over the past month. He said he hopes to ship my kit within 2 weeks (not completed now).
MikeD '87 930
Old 06-30-2025, 07:28 AM
went to test bench today !
331 hp and 413 nm torque ..
+ Guy was impressed with peep his config!
He did it all from home, i just send him some logs to check evertthing . He adjusted accordingly ..
Old 07-01-2025, 04:16 AM
