Button on 930 dash
What is the button (at arrow) for in this picture.
The owners manual does not acknowledge it.
No such button on my '87...but jn it's place is a small air vent behind which I believe is a thermistor of sorts as part of the heater control apparatus.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Non User
Is that a button or a molded dash “plug” for an uninstalled accessory switch?
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
It's a spot for a heater fan controller.
Introduced on the 930 in 1984. My car has it.
Interesting. In my Cali '86 it's the intake for the temperature sensor mentioned above to control the auto heat (which works!)
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
I think it was just an '84-'85 thing
'81 924 Turbo (931) '87 944 Turbo (951) '84 911 Turbo (930)Flachbau '89 928 S4 '04 911 Turbo (996) '08 Cayenne Turbo (957) |
BauerR, where did you get the center console from, I've been looking for one shaped like that for years. Thanks.
Sonderwunsch. It's all Special Wishes and Interior to Sample
Thanks for the reply. Very nice!
7.0:1 > 11.3:1 > 7.0:1
Era gone by but that interior is sweet.
In the early G-body cars - 1974 and 1975, the intermittent wiper swich was mounted there. Starting from 1976, this switch is located between speedo and clock, leaving the old location empty, just molded shape left there. It might have been used occassionally for other purposes, as in the example shown by BauerR.
See below example phitos from 74 and 75 cars, found somewhere on the web. ![]() ![]() Starting from, 1986 they used this place on the dash to install air inlet to temp sensor (there's a tube behind this little grille leading to temp sensor. Last edited by albinski; 08-28-2024 at 01:17 PM.. |
Perfect spot for the brake bias adjuster knob!!!
