Bad Leak. Need Help.
I have a 3.3 930 that was running great yesterday. Went out to drive today and noticed a pancake size leak puddle under the center of the muffler.
Moved the car inside and got it in the air. Oil/Fuel was leaking from turbo/exhaust connection and cylinder to header connection. When ignition is on, it pours fuel. Did a leak down and it came back solid (less than 5% all around). Any ideas on where to start or the severity of this issue? ![]() ![]() ![]()
1991 Turbo 1997 Turbo 2004 Cup 1996 C2 1989 C4 |
Does your CIS air flow sensor move freely? The flow sensor should shut the fuel flow in the fuel distributer when engine is not running.
EDIT How long did the fuel pump run without engine running? Possibly should also drain the oil out of crankcase.
87 930, Last edited by 908/930; 09-12-2024 at 06:07 PM.. |
Your fuel pump should not run unless the car is being cranked over or it's running ... Sounds like your safety air flow switch for your fuel pumps is disconnected or not set correctly and its only now an issue because you have that injector stuck open on that cylinder ..
The car can operate without issue with the safety switch not working or disconnected not recommended but many cars do . if its only leaking from that one cylinder pull the injector and see if it sprays with just the pumps running if so replace the injector. if they are old you may want to do them all. if all of the injectors are l spraying by you may have a stuck plunger in your fuel distributor . put a cis meter on to confirm pressures .. my money is on a single bad injector. Last edited by gorskined; 09-12-2024 at 10:45 AM.. |
Thanks. I'll give that a shot.
I don't think these injectors shut off its all in the fuel head but I could be wrong
Not sure about the vintage of your 930. If applicable check the rear round relay. A faulty relay can affect the fuel pump ignition on issue.
The pumps should not be running. One problem.
Having said that , they should not be pumping fuel to the cylinders - without the engine running. You can have the pumps running but all fuel would/should be cycling back to the tank. It sounds like 2 problems. Pumps on and an injector(s) open. What I would do is pull the culprit area injectors, hook them up externally, and see if they are sraying fuel with pumps on. They should be closed. They should only be opening when the airplate opens - this mechanically opens the metering slits in the fuel head. So , just double guessing this one - the pumps on has been a previous issue - but not noticed. Until an injector has failed to shut off . Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
FSM gives injector crack pressure for a '78 930 as 2.1-3.2 bar. So ~31-47 PSI are the lower/upper limits of spec.
Things to check for a CIS injector:
Any of these tests fail - replace.
'77 S with '78 930 power and a few other things. |
The universe is giving you a sign. Throw that cis in the garbage and go efi
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
I would struggle with EFI - because IT technology and me don't get on. You should see my phone. The CIS is not complicated - when the time is spent figuring it out. So, I respectfully, beg to differ. Alan
Brando
Assman! That's good. The young-uns won't follow that.
Sorry about the leak.
Turbo powa! 1977 911s. it's cool |
Banned
Same issues with mine
Banned
How do I get around this forum?
The metering slits have to be open in order to send fuel to the injectors. Stuck plunger maybe or misaligned metering arm hanging up. Tell-tell sign would be audible injectors squealing as soon as you turn the key on.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
if the issue fixed it self, its a faulty injector that that didn't seal . you may be good for years or it way drip intermittently . i would recommend replacing the injector
