Crotchety Old Bastard
The AAR works off a similar design as the WUR, using heat to bend a spring. As long as you have heat you have bend, so yes the AAR will continue to close with engine heat as well as electric heat, same as the WUR. That is what keeps the idle (AAR) and control pressure (WUR) correct at warm start-up. There is diminishing return as the bimetallic spring reaches its limit of motion.
If you are not going to adjust the AAR to compensate for missing smog equipment it can simply be removed and replaced by splicing in a vacuum line to the same thermol time switch that is used by the ignition distributor. Automatic function, no fiddling. If you do not have this TTS then use a solenoid. That huge CIS phalic symbol goes away.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
As for the TTS switch to the dizzy...mine is there but I doubt it's working; cannot get any voltage readings off the plug but works when bench tested.That will just lead to another topic altogether re: timing.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
