MS3 Pro Idle Control
Hey all,
Hoping I can get some help with my EFI conversion. I’m converting my 3.0 to EFI using a MS3 Pro and a Carrera manifold. Are you repurposing the stock idle control valve on the manifold? If so how do you have it wired? If not using a Carrera idle control valve, what are you using to control your idle? Thank you! Daniel |
I use the Ecumaster EMU Black and the stock idle valve. Here's a pic of my settings... no idea if they are correct but it works!
12V to the centre pin then the two aux connections to the other pins. ![]() Duty Cycle Table
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Thanks Mike! What you provided gives me a good start.
Iav
![]() This is what I'm using with my MS3 Pro Evo with stock Carrera manifold and IAV valve.
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Philip- thank you, this will certainly help me!!!
yes you can use a stock 3.2 carrera idle control valve, I did that when I converted my old 3.2 to full EFI with Microsquirt, I did that because it was there from the begginning, but since you are starting from a CIS then I strongly recommend to use a universal one (like this one from Clewitt https://www.clewett.com/index.php?main_page=product_info&products_id=434), which is more user friendly and easier to connect.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
check the attached photo, this is how I did it with the Microsquirt.
Thanks Kamaro for the idea and most importantly the wiring advise, this will certainly help me. I forgot to mention I have a complete 3.2 Carrera intake with all the attachments😉. So I would like to try and repurpose the ICA it came with.
