MS3 Pro Idle Control
Hey all,
Hoping I can get some help with my EFI conversion. I’m converting my 3.0 to EFI using a MS3 Pro and a Carrera manifold.
Are you repurposing the stock idle control valve on the manifold? If so how do you have it wired?
If not using a Carrera idle control valve, what are you using to control your idle?
Thank you!
Daniel
Old 07-21-2025, 04:32 PM
I use the Ecumaster EMU Black and the stock idle valve. Here's a pic of my settings... no idea if they are correct but it works!
12V to the centre pin then the two aux connections to the other pins.
Duty Cycle Table
Always learning.
www.aircooledporsches.com.au
Old 07-22-2025, 02:40 AM
Thanks Mike! What you provided gives me a good start.
Old 07-22-2025, 04:53 AM
Iav
This is what I'm using with my MS3 Pro Evo with stock Carrera manifold and IAV valve.
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 07-22-2025, 09:07 AM
Philip- thank you, this will certainly help me!!!
Old 07-22-2025, 09:42 AM
yes you can use a stock 3.2 carrera idle control valve, I did that when I converted my old 3.2 to full EFI with Microsquirt, I did that because it was there from the begginning, but since you are starting from a CIS then I strongly recommend to use a universal one (like this one from Clewitt https://www.clewett.com/index.php?main_page=product_info&products_id=434), which is more user friendly and easier to connect.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 07-23-2025, 03:53 AM
check the attached photo, this is how I did it with the Microsquirt.
-1987 928S4.
Old 07-23-2025, 03:58 AM
Thanks Kamaro for the idea and most importantly the wiring advise, this will certainly help me. I forgot to mention I have a complete 3.2 Carrera intake with all the attachments😉. So I would like to try and repurpose the ICA it came with.
Old 07-24-2025, 04:41 PM
