911 turbo special grommet
VW part number 021119563
Located down near the left foot of a driver's side rear passenger.
Actually a body plug, that can be cut open...
The dealer installed boost adjustment hose pair were routed through this hole. The grommet is in terrible shape.
Has anyone figured out what modern grommet fits this? Seems to measure about 45mm
Old 08-01-2025, 01:05 PM
mark houghton's Avatar
Should be able to find at places like Home Depot, etc.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-01-2025, 04:21 PM
Alan L's Avatar
It is just a regular grommet. Measure the OD - in the slot. That is your sizing. Then you are looking for a 'Blanking ' grommet of that OD.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 08-01-2025, 11:37 PM
Thanks, I didn't realize these were called blanking grommets. Have located a couple options I can try.
Old 08-02-2025, 06:11 AM
