Over boost switch?
Lately developed a problem when I get on the boost suddenly, everything cuts out hard. Like face through the windshield hard. First time it happened, I thought I'd blown the engine. Limp to side of the road, give it a minute or two and then all is well.
Car has not been running hot when this happens, and is not RPM dependent. Any thoughts from the collective? Many thx DB |
Need more information. First, what year is your car? It might not have an overboost switch.
1985 Euro version car.
1 BAr spring Larger intercooler Rarely late exhaust Everything else stock |
What pressure was your boost at? Make sure you are not over boosting and the switch is ok. Take the switch off and apply pressure to see when it opens. Or you can try bypassing it, just install a small wire that is attached to ground with a spade terminal on it. Do not leave the bypass on permanently.
87 930, |
i would check your wastegate operation / lines
Really only two possibilities. You're either over-boosting and the switch is reacting as it should, or your switch is faulty. You could unplug the wire to the switch and ground it out to bypass the switch, and take a boosted run while closely watching the boost gauge. I don't remember exactly but I think a properly functioning switch will activate at 1.2 bar.
Suggestions from other folks here are right on.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Yep - supposed to cut at 1.1 bar - so watch the gauge in case you do the bypass and it doesn't cut. Seconds are important - that tach gauge ain't super accurate. If it gets a shade over 1 bar and ain't cut, shut it down. Then as above , remove the switch and either bench test or replace.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
rear fuel pump
you can thank me later |
Either way, I couldn't put much more than 1.0 bar to it with my crappy Chinese MightVac, and it did not open.
a small air compressor with a regulator works well or any bottled gas with a regulator argon, nitrogen, oxygen ex set reg to 10 lbs then slowly turn the reg to increase pressure.
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body |
Disconnected over boost and still have problem. I am thinking it is likely a fuel pump relay problem. Have a couple on order.
DB |
