Chain fence eating turbo
Running a turbo without the intercooler connected
Reading the webs in its' infinite misinformation cesspool, do you think you can overrev or overspeed a turbo if the intercooler is NOT connected venting to the atmosphere?
99% of the web says 'yes', but I found a turbo engineer who states otherwise. He states there is still resistance of air on the compressor side into the atmosphere and is not a problem as the engine is not producing enough exhaust airflow due to the lower HP output, essentially. I also have blown off hoses many times under full boogy without grenading a turbo yet. What are your thoughts? Why I ask, is I plan on massively revamping the intercooler piping on my custom Treadstone unit on a Carrera 3.4, but I want to continue to drive the car if needed as this may take weeks. I thought of hooking direct without the IC and not getting into the throttle, but that probably would not be wise.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Unless I misunderstand your question, well of course you can't run at all without the intercooler connected to the intake, for CIS anyway, unless you rig up some sort of MacGyver plumbing.
Isn't the issue that if you don't vent out the boost pressure - or recirculate it- when shifting gears, you get all this back pressure against the turbo and it stalls the spin?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. Last edited by mark houghton; 10-08-2025 at 12:58 PM.. |
Yeah Mark, I am EFI. Carrera 3.2 with a turbo, so no CIS.
Ok, that 'splains that!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
If that was true then I should have replaced every turbo when I had a slipped out hose during a full boost blast. which I did endless times and will still do it.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
I think it’s more than likely ok to run them unconnected. |
Ingenieur
You can and you will overspeed the turbo. You won’t see any particular effect though. The shaft and bearing system is designed to remain relatively stable to at least 150% of design speed. Event that level it may only cause a slight wheel rub.
The turbine wheel burst speed is also very high, and the HCF limit is also very high. The aluminum compressor wheel burst speed is also at least 150% of the design speed. The problem for the compressor wheel is LCF. You will eat up a bunch of LCF life with a big overspeed, but this is not visible. These old aircooled engines are running at pressure ratios that are not high enough to make LCF a very big problem though. I don’t think it likely that anybody would experience a failure from running a short test without the intercooler. |
Thread Tools | |
Rate This Thread | |
