Chain fence eating turbo
Running a turbo without the intercooler connected
Reading the webs in its' infinite misinformation cesspool, do you think you can overrev or overspeed a turbo if the intercooler is NOT connected venting to the atmosphere?
99% of the web says 'yes', but I found a turbo engineer who states otherwise. He states there is still resistance of air on the compressor side into the atmosphere and is not a problem as the engine is not producing enough exhaust airflow due to the lower HP output, essentially.
I also have blown off hoses many times under full boogy without grenading a turbo yet.
What are your thoughts?
Why I ask, is I plan on massively revamping the intercooler piping on my custom Treadstone unit on a Carrera 3.4, but I want to continue to drive the car if needed as this may take weeks.
I thought of hooking direct without the IC and not getting into the throttle, but that probably would not be wise.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-08-2025, 08:46 AM
mark houghton's Avatar
Unless I misunderstand your question, well of course you can't run at all without the intercooler connected to the intake, for CIS anyway, unless you rig up some sort of MacGyver plumbing.
Isn't the issue that if you don't vent out the boost pressure - or recirculate it- when shifting gears, you get all this back pressure against the turbo and it stalls the spin?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-08-2025, 12:28 PM
Yeah Mark, I am EFI. Carrera 3.2 with a turbo, so no CIS.
Old 10-08-2025, 01:44 PM
Ok, that 'splains that!
Old 10-08-2025, 03:49 PM
If that was true then I should have replaced every turbo when I had a slipped out hose during a full boost blast. which I did endless times and will still do it.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 10-08-2025, 11:12 PM
Same. I’d imagine at full tilt, the turbo is spinning its max RPM, then losing a connection would send them to the stratosphere bet it never does.
I think it’s more than likely ok to run them unconnected.
Old 10-10-2025, 04:28 AM
Ingenieur
You can and you will overspeed the turbo. You won’t see any particular effect though. The shaft and bearing system is designed to remain relatively stable to at least 150% of design speed. Event that level it may only cause a slight wheel rub.
The turbine wheel burst speed is also very high, and the HCF limit is also very high.
The aluminum compressor wheel burst speed is also at least 150% of the design speed. The problem for the compressor wheel is LCF. You will eat up a bunch of LCF life with a big overspeed, but this is not visible. These old aircooled engines are running at pressure ratios that are not high enough to make LCF a very big problem though. I don’t think it likely that anybody would experience a failure from running a short test without the intercooler.
Old 10-10-2025, 04:53 PM
I need help on initializations LOL. HCF, LCF, etc
Old 10-17-2025, 04:10 PM
Happiest when Tinkering
gsmith660's Avatar
I frequently pop my up pipes particularly at the throttle body that is why I now have a tube bead tool because I am doing this at 7 psi I can only imagine when I start bumping up the boost. I have had no ill effects so far.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 10-19-2025, 08:05 AM
Wow, only 7 and they let go? I’ve ran 15-20.5 PSI since 2007 with only a few times letting go. I’d say 3-4. Usually my fault for not securing properly and square.
Old 10-19-2025, 11:18 AM
gsmith660's Avatar
No bead will do that is why I have a bead roller now
Old 10-19-2025, 11:33 AM
The worst is polished aluminum tubing with silicone couplers.
Old 10-19-2025, 12:39 PM
gsmith660's Avatar
Yes I agree
Old 10-19-2025, 01:04 PM
