What areas does adjusting the WUR pin affect? AFM screw?
Basically wondering if adjustments to WUR pin and AFM screw affect all areas of fueling, or just idle or other specific conditions.
I’ve been slowly sorting out a car I bought which has a 3.3 turbo motor swapped into it with seemingly all necessary supporting accessories. It has had some ups and downs with how it’s running, but think I’m making progress. WUR is a 153 part number, and I believe the fuel head is stock but if there’s a way to verify or check these or other important components please let me know. I have a wideband and boost gauge installed, as well as a manual boost controller. I took apart the WUR, cleaned it up, then adjusted pin height. Months ago when I did this I was able to get all pressures in spec, barely, but now CCP is reading lower and I’m not sure why, but car still starts and runs fine. Currently, system pressure is 6.9 which is correct. CCP is 1.5 which is .4 low, but WCP is 4.0 which is just a hair high. With these pressures and how the AFM screw is currently set I am seeing: 11.0 AFR at startup, quickly climbing to… 13.2 AFR after a couple minutes idling 13.2 AFR steady idling 13.2 AFR cruising 10.5 AFR in boost, about 10 psi currently So… it works, but it’s not perfect. I don’t want to touch this without being clear on how to make improvements. Can someone explain what adjustments to WUR pin height and AFM screw affect? I’ve read different things and want to be sure. Or are there any other adjustments I should be looking at? If I can lean things out a bit all around that should be an improvement, but I want to learn and understand first before doing. |
Crotchety Old Bastard
You can go here and click on the CIS Primer for educational info:
https://rarlyl8.com/ The pin you are referring to adjusts CCP only (cold control pressure). The idle mixture screw will fine adjust the WCP (warm control pressure) but also affects all other parameters to a lesser degree. Your AFRs look acceptable for everything but cruising which should bump 1 unit higher than the AFR at idle. This is unusual. Double check for vacuum leaks.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thank you, so since my CCP is low I could raise the pin slightly (or leave it if it’s running ok), and no other impact of adjusting that?
Sounds like I could turn the idle mixture screw a bit leaner and it might move me slightly in the right direction? 10.5 AFR at 10 psi of boost could be .5 to 1.0 leaner as well, couldn’t it? Currently at 10 psi but would like to be at 12-14 psi up here in the mountains of CO if everything else is under control. I smoke tested earlier this year and found no vac leaks. |
Optimally all of the fuel pressure settings would be within the spec range, but it is more important that the engine runs well. System pressure sets and moves all the baselines so that has to be in spec as does voltage to the fuel pumps and all the associated wiring fuses and relays. Adjusting outside of spec range is typically done due to sub-par performance of the components.
It sounds like your WUR may be getting lazy and not fully leaning out as the engine warms. Measuring system pressure and cold/warm control pressure will help verify. The engine AFRs at idle should automatically jump one point at cruise, no adjustments needed.
I'd definitely second what Brian says about "more important that the engine runs well".
It's way too easy to focus on the numbers and not the result. I know I've been guilty of trying to chase perfect pressures and AFRs when, honestly, who cares what the number is if it runs well. I've often screwed myself up by chasing that decimal point when I should have accepted it because it runs great.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
I fell into the trap of chasing the wur pressure chart. I have a 76 3.0l with an ic and sc cams. my motor doesn't like 3.0l factory wur fuel pressure chart ( so happy i had it rebuilt it to make it fully adjustable ) . I eventually gave up on it and set the car off of the way it performed and the afr# my final pressures are closer to the 3.3l wur chart curve . . i cant seam to lean out my full boost past the 10.5. i would love to see 11 but hey its old technology . My car is a fair weather driver so i would rather stay on the rich side under boost .( im still not convinced i dont have a air leak under full boost, that's on the list for this winter ) my afr # are almost exactly the same as yours. my car didn't like the 13s at an idle i eventually tweaked my cis afr screw. That deflects the air sensor plate and was able to to smooth it out, i think its high 12s at an idle. .. another interesting thing i noticed after i installed permanent cockpit fuel pressure gauges is at an idle 13.3 volts i am making 92 psi fuel system pressure and while cruising 14.2v i am making 97psi fuel system pressure. The only thing i really pay attention to is the Afr. i don't know how they worked on these back in the day before the real time wideband afr gauges.
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body |
