Crew Chief
prooutlaw's Avatar
Problem after Intercooler install
I installed a Garettson Longneck Intercooler on my '83 930 with the C2 turbo bypass assembly.
The car runs great until the 2-3 shift , that is when it hesitates for a about a second( like you forgot to press the Gaspedal ) then it pulls fine.
I changed the Bypass valve and it did not fix it .
then i reinstalled all the stock intercooler components including the Bypass manifold assembly and the problem was gone.
Any ideas ?
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 11-06-2006, 05:16 AM
Me like track days
Craig 930 RS's Avatar
Boost leak. BTDT, 'rubberband delay effect' was my description when it happened here -
Just a guess
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-06-2006, 09:42 AM
Crew Chief
prooutlaw's Avatar
Craig,
i was unable to find a leak , where could a leak be large enough to cause this deadspot ?
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 11-06-2006, 12:17 PM
Me like track days
My IC partially popped off the inlet tube - causing a situation that I can describe as:
"boost had to build to a point to adequately pressurize the intake system - caused a hugely noticeable delay in boost buildup"
Where the IC inlet joins the IC -
Old 11-06-2006, 12:36 PM
Me like track days
Also check the join to the manifold -
Old 11-06-2006, 12:37 PM
7.0:1 > 11.3:1 > 7.0:1
Did it have this 2-3 delay since since you originally installed the I/C or did the delay start sometime afterwrds?
Try lifting hard on the ends of the intercooler to see if it moves up off the O-ring seats. The O-ring seats are almost 3" dia. At one bar of boost this equates to 105 Lbs of force pushing up on each end of the I/C.
Jim
Old 11-06-2006, 07:11 PM
Me like track days
Popped mine right off......because I was a moron and didn't tighten the strap bolts from IC pipe to IC.
Made all kinds of weird sensations - this was all post-rebuild-first-time-on-track so I was wondering WTH was going on. BIG lag in the truest sense of the word!
Old 11-06-2006, 09:58 PM
Crew Chief
prooutlaw's Avatar
All the joints look fine ,
it builds Boost quick thru 2nd gear and sometimes into 3rd but then the boostgauge bounces and it acts like you took the foot completely off the throttle ( boost drops to 0 ) for a second or so and then it is back at full boost and runs fine from then on until you go thru the gears again
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 11-07-2006, 03:51 AM
beepbeep's Avatar
You are sure you aren't hitting the overboost switch?
Boost builds higher in higher gears, It might be so that you are just tripping the switch in 3-rd.
Thank you for your time,
Old 11-07-2006, 06:20 AM
Crew Chief
prooutlaw's Avatar
I do not use the Overboost switch ( dont have one ) and the curcuit is bypassed
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 11-07-2006, 07:35 AM
Me like track days
Can you post some pictures?
This way we might get a better idea of the layout so a leak or ? can be located easier -
Old 11-07-2006, 09:04 AM
Crew Chief
prooutlaw's Avatar
At this time i have the stock intercooler back on the car with the stock bypass manifold
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 11-07-2006, 09:15 AM
Hmmm, if the boost drops to zero rather suddenly it makes me wonder if the BOV is opening up for some reason.
Where did you connect the actuator hose?
Anything T'd into the actuator hose?
Old 11-07-2006, 06:39 PM
