Low Oil Pressure
I am hoping that it is a bad gage / sender... looking for some suggestions on other things to check.
Car runs, sounds awesome. Normal puffs of smoke on start-up, totally gone within 2 min. Zero oil leaks. On start, oil pressure is steady at 4. Acts normal until gets warmed up. Then pressure will not go past 2. At idle, 1 to 1.5 after warmed up. Been dealing with the normal electrical bugs recently and need to replace the alternator/regulator (have to trickle charge every night). Oil level is spot on, burns maybe 1 quart every 4,000 miles. I know the pump is working because front mount cooler and fender mount cooler are both hot after driving. Changing oil this weekend and will check. 1. Debris in Oil Sump. 2. Debris in Oil Tank. 3. Debris in Filter. If all clear, can I expect that it is the gage/sender? Thanks in advance.
___________________ Ryan 2001 996 Twin Turbo 1982 930 |
A fellow Pelacanite
Might be just a connection. Good luck.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Thanks Nathan
All that sounds normal to me... my car does the same thing... it won't exceed 2bar once warm and @ idle.
I'm not quite sure about the puff of smoke upon start-up, for 2 minutes! Mine will only puff smoke occassionally and that's only for 5 seconds upon startup.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
A fellow Pelacanite
Maybe you are running very thin oil.
I run Mobil 1 5W-50 synthetic oil. No extended puffing upon start for me. Only does it occassionally and only for a few seconds.
I have no oil leaks whatsoever and I still get under 2bar oil pressure @ idle, once at operating temps. I believe this is normal.
Thanks guys - running Royal Purple XPR 20/50. Going to the shop on Tuesday to check - and replace the Alternator.
A fellow Pelacanite
What oil pressure do you get at say 3K RPM when hot ?
The manual says that it is not uncommon for the low pressure oil light to come on at idle once the oil is hot. I'm not sure what the pressure is to turn on the light but at 1,000 rpm you are looking at 1 bar or less with hot oil. Also remember what happens when the oil gets warm; the entire oil system is opened up so that the volume of oil and the lenghts of tubing are much greater than when it is cold. Then you have the friction and drag of the circuit but the oil pump is only turning over at low rpm. On another note, I bought a new temp and press gage from NHS and my temp went down 75 degrees and my oil pressure went up .5 bar.
911rudy Last edited by 911rudy; 02-02-2007 at 07:50 PM.. |
1-1.5 bar oil pressure at running temp and a quart every 4k is very normal
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
I really appreciate everyone's help with this - Nathan, Oil pressure at 3,000 RPM = 2 bar, had it up as high as 3,300 RPM - still 2 bar oil pressure - didn't push it any further. Rudy, I do feel that it may have something to do with the 25 year old gages and sending units, but also wanted to get inupt on anythign I might be on the lookout for or that I had missed.
A fellow Pelacanite
20-50 is a thick oil. I run a thinner oil (not synthetic though) in my 3.2 carrera. I get 4.5 bar at high rpm.
On my 930 oil pressure was similair but I do not know what oil was in it. You might have a problem.
The oil light switches on @ .5 bar or about 7 PSI. My theory on oil pressure is; if it doesn't knock or explode, it's suffecient. Enjoy the ride.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait! |
Forced Induction Junkie
Check your wiring while you are at it. When the engine is up to temp, watch your oil pressure gauge while you turn your headlights on and off. If you get different pressure readings, you have a wiring or alternator issue.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
FUSHIGI
So, if rebuilding and one wanted to carry greater oil pressure as insurance, what are some good options?
All - just got off the phone with my wrench and there is GOOD NEWS! All seems to be well and related to a loose connection on the alternator. Gage operates at 8 volts and - didn't know that - and when I would get home the meter would say 6 or so - thus low oil pressure reading... wshew...
Pavulon - read an article in Excellence about a wicked 930-505 that S-Car-Go built a couple months ago, they moded the case for a 964 pump I believe. Other than that, I am not sure that there are other options and now that I think about it - you really wouldn't want to do that anyway... As, you would only be masking what is a most possibly a MUCH larger problem. It's kind of like those extreme makeover shows where they make really ugly people pretty. Why, well because some poor guy is going to see her, say, man she's hot, marry her, and have kids - Damn UGLY KIDS. So, for the sake of the children don't mask an ugly problem with a pretty gaget.
FUSHIGI
You lost me...How is an accurately reported higher oil pressure at operating temps a bad thing? I'm not talking crazy high pressure but 7 psi at idle seems marginal to me...but I would not claim to be an expert....just trying to learn is all.
Cults require delusions. |
You can change the fittings at the cam towers with a newer version that has a restrictor orifice built in. This will improve your idle pressure. Wanye has them in the catalog PEL-CAMRSTN. You can ID them by a groove in the center of the hex portion of the fitting. Check yours before ordering to be sure they haven't already been changed.
