-   -   MY 3.8 twin turbo build up. How much HP do you think? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/338180-my-3-8-twin-turbo-build-up-how-much-hp-do-you-think.html)
Maltese Falcon 05-28-2007 10:11 PM
Garrett tel# 310-517-1981 Fax# 310-534-5941
sorry no email contact. Call and ask for an engineer in turbo or turbo kit development.
Marty
WydRyd 05-29-2007 12:07 AM
Originally posted by speeed racr
The turbos are brand new. They only have about 15-20 min of run time on them. I am running oil through the water passage.
From my personal experience with the Garrett BB's, you don't need to run oil through the water passages. That's how I run mine. Oil cooled only and the water ports are left open. I run my car pretty hard and it's my daily driver and I have no oiling issues whatsoever. -4AN oil feed, NON-restricted.
Candelaria 05-29-2007 05:03 AM
I agree, no water needed, been using these since they came out, on air cooled engines, no problem at all, you can use oil to cool them out, cheers, Candy.
speeed racr 06-01-2007 11:37 AM
Here is the new set upand they still leak.http://forums.pelicanparts.com/uploa...1180726574.jpg http://forums.pelicanparts.com/uploa...1180726594.jpg http://forums.pelicanparts.com/uploa...1180726605.jpg
speeed racr 06-01-2007 11:46 AM
Marty
I called them they were no help. thanks anyway.
Candelaria 06-01-2007 11:51 AM
You need to clock the center housing oil outlet 90 degrees from horizontal, also the hole in the valve cover must align with the oil return tube, also it seems to me that the turbos are positioned to low. You may try to scavenge the oil thru the main sump or use a better (bigger) scavenge pump. Candy.
