MY 3.8 twin turbo build up. How much HP do you think?
Its a 3.8 built with Carrillo rods, EVO cams ported heads. Twin Garrett GT35r ball bearing turbos. Motec engine management. I wonder how much HP it will make?
VERY nice! Depends on how much boost you intend to run?!?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
I will add more pics as we progress on.
![]() My friend helping to assemble the turbos. http://forums.pelicanparts.com/uploads10/DSC02326b1175057600.jpg[/img] |
![]() what a dork. 1.2 bar. with t3/t4 60s it made almost 700 hp at 1 bar before.the rebuild. On stock internals. I am also running 2.5 intake pipe. Last edited by speeed racr; 03-27-2007 at 09:00 PM.. |
Here is the video.of the car when my friend Alex owned it.
http://media.putfile.com/Alexanders-Protomotive-993-4liter-101147MPH |
Well it should breath alright, but the real question is what size injectors you plan on using
Yeh, I would have said mid->high 700's
Me like track days
A LOT
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I would think that beast should make closer to 1000...especially with individual throttle bodies! Enough turbo to support 1200HP, then consider 8.5hp/lb/min of air flow for the air-cooled 2 valve motor and you get~1020HP...if you can put enough boost to it.
Cleve ![]() |
Banned
800+ HP., I have a similar setup, but without the tb's, and 3076's instead of 3582's turbos, it is making 807hp at the wheels at 1.45bar, with a good tune yours should make 900+ at similar boost levels.,keep us posted.,Candy.
Delicious motor!....BTW we have the same glasses........................................... .......................and tattoo!
Yasin
Ole Skool - wouldn't have it any other way |
I think you'll have WAY TOO MUCH HP... so I think you should give me some
Bad@$$! Did you bore the case for the 3.8 cylinders or did you use slip ins? You could run that thing on low boost and eat Ferraris and crap Corvettes
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Have you flame ringed the heads/liners for the extreme boost levels you plan to run?
Cool engine!
Suggestion: check head temps while on-dyno. It will probably deliver ungoodly amount of power in short bursts but I suggest monitoring head temps and tuning the motor so they never exceed 210 deg. C (if you used N/A heads) or 230 deg C (if you used Turbo heads). After that, heads go soft/plastic and all kind of bad things start to happend.
Thank you for your time, |
NICE. 829HP what do I win?
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
SLIP IN MAHLE PISTONS.
![]() Quote:
Banned
By no means go over 1 bar with slip ins!! if you want it to last some.,Candy.
