steps to take when one cylinder seems to be running lean..
What are the first things to check when you find one of your cylinders running lean?
I pulle dmy plugs last night, they all seem fine except number 5, it was white! should I check the injector first?
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) |
yes.
Is it just a matter of removing it and checking/verifying if it squirts? I guess I could check the manual.
Me like track days
Crack pressure, leakage, volume - have a pro check it.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
thanks Craig, I'll get around to pulling it later this weekend. Are they easy to remove? i don't have to remove a whack of other stuff as well do I?
I replaced the injector and still nothing. The plug is still lighter than the rest, although seemingly better than before. I have driven the car about 500 miles since I changed it, so I figured the plug is pretty much at the color it's going to be now isn't it?
I guess the next thing to verify is the fuel distributor?
Wo ist die Rennstrecke?
A mile or so would have told you. Be real careful driving it - you could melt a hole in the piston pretty easily.
You might want to remove the fuel line (from the fuel head to the inj) and clean it. The connection to the fuel head (the fitting on the fuel head for that fuel line) should be removed and inspected for garbage. |
Me like track days
Definitely check the tiny filter at the fuel head - a real pita, but a few of mine were collapsed - available from Imagine Auto (no one else has them AFAIK):
![]() ![]() Testing the injectors: ![]()
Smart quod bastardus
Can you explain more the filter location in the fuel head?
Are there six filters, one for each injector line? Or is there one fliter located at the fuel line coming into the fuel head? Can you show a picture of the plug that was running lean? Thanks for the info, Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
I'll try to get a picture of the plug next to another one? but no guarantees as my camera is not good with closeup shots.
I am also curious about the fuel filter at the distributor. unbolting the line and checking it should be simple enough. Is it safe to assume I should put in new crush washers at he fuel head when putting it back together after having cleaned it? Also, for cleaning, I can use aerosol carb cleaner right?
Me like track days
Right inside where the fuel lines connect to each of the 6 banjo bolts.
The filters are miniscule. New washers are also a must, trust me. Imagine Auto, What are you gonna clean? I wouldn't. The head itself it really fragile, esp on the bottom plunger part. You screw that up and you are.......screwed. DOn't get 'clean crazy' and spiff it up for nothing. Clean it up *before* removal, also a must. Edit: 6 filters
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 09-28-2007 at 12:52 PM.. |
I meant just clean up the fuel line, make sure it's clear.
Me like track days
How are the wires, cap, and rotor?
less than 6K miles on them. It was like that the first time I changed the wires/cap/rotor as well, so I'm pretty confident in eliminating that as a potential cause.
I went to take a picture today and noticed the plug that I say is light is actually the right color.. it's all the others that are dark.. now, that being said, it still means that no.5 is leaner than others.
All this fuel distributor inspection is going to wait until winter storage unfortunately. I still ahve anotehr month or so to enjoy her before I put it away.
Forced Induction Junkie
When is the last time you put Techron in your fuel tank? Run a full tank of fuel with Techron before you store the vehicle. Then in the Spring, add Techron to the tank and run that through the system.
When the vehicle is in storage, put Stabil fuel stabilizer in the tank to prevent varnish buildup.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
