-   -   934 Project Update #2 (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/347316-934-project-update-2-a.html)
cgmeredithjr 05-18-2007 03:40 PM
Stripped, Cooked, and Dipped! Clean slate to start build with. The other nice thing about stripping the car all the way down is that you can find any previous damage to the car and make sure it has been repaired properly. The car will now receive seam welding and a complete custom cage by Chad Ernst of Fat Cat Fabrications. The stripping was done by Carolina Chem Strip of S.C., Inc. located in Fountain Inn, SC. Dave Ellington and his guys did a great job and it only took 24 hours to complete.
Cleve:D http://forums.pelicanparts.com/uploa...1179527644.jpg http://forums.pelicanparts.com/uploa...1179527681.jpg http://forums.pelicanparts.com/uploa...1179527714.jpg http://forums.pelicanparts.com/uploa...1179527747.jpg http://forums.pelicanparts.com/uploa...1179527783.jpg http://forums.pelicanparts.com/uploa...1179527816.jpg http://forums.pelicanparts.com/uploa...1179527848.jpg http://forums.pelicanparts.com/uploa...1179527879.jpg http://forums.pelicanparts.com/uploa...1179527911.jpg
NathanUK 05-18-2007 04:17 PM
Do you know if that has removed the zinc plating at all ?
cgmeredithjr 05-18-2007 05:05 PM
Yep, removed the Zinc which is necessary to perform the seam welding. The car will be be powder coated and then wet painted on the exterior body panels.
Cleve
WydRyd 05-18-2007 08:50 PM
WOW, what a project! Keep the pics coming ;)
NathanUK 05-19-2007 01:16 AM
Cleve
Doh, I am so dumb... Hehehe I forgot about that.
Did the dipping remove it ?
cgmeredithjr 05-19-2007 05:44 AM
Yes, I am pretty sure that the acid dip is what removes the zinc, but the oven part of the process may contribute also.
Cleve
NathanUK 05-19-2007 10:26 AM
Thanks, I have heard how difficult it is to remove the coating prior to welding. I have had experience with these types of coatings and they are not fun to remove.
DDDD 05-21-2007 09:18 PM
I am jealous.
I would love to have a 911 unibody stripped down and ready to build.
One day I'll convince my wife that I need two 30 year old Porsches instead of one.
My goal is to do a 74 RSR and paint the interior red. Put a 3.6 N/A in it. Good times!
Keep us updated on your project.
cgmeredithjr 05-22-2007 06:03 AM
Originally posted by DDDD
I am jealous.
Convince your wife? Why would you have to do that? Mine has no clue!
Here are some pics of a 934 replica, this car was built on a 78 tub with original 934 parts from a crashed 934 race car. My car will have a similar stance with the 18" wheels.
http://forums.pelicanparts.com/uploa...1179838569.jpg http://forums.pelicanparts.com/uploa...1179838579.jpg http://forums.pelicanparts.com/uploa...1179838585.jpg http://forums.pelicanparts.com/uploa...1179838596.jpg http://forums.pelicanparts.com/uploa...1179838605.jpg http://forums.pelicanparts.com/uploa...1179838615.jpg http://forums.pelicanparts.com/uploa...1179838623.jpg http://forums.pelicanparts.com/uploa...1179838629.jpg
cgmeredithjr 05-22-2007 06:21 AM
Micke Svens at Spezial Motorer is about to release this Flat Fan set up...I wonder how much he will be charging? Looks pretty cool! www.spezialmotorer.com
http://forums.pelicanparts.com/uploa...1179840080.jpg http://forums.pelicanparts.com/uploa...1179840090.jpg http://forums.pelicanparts.com/uploa...1179840098.jpg
NathanUK 05-22-2007 08:52 AM
Was the factory part like that or did it work a different way ?
jrottn 05-22-2007 09:00 AM
holy moly that is a sweet setup
sure would go nicely with my 934 headers
come on powerball!
WERK I 05-23-2007 08:09 AM
Factory used V-belt setup, not the new improved serpentine type. Everything else, though, looks like it came from the factory.
NathanUK 05-23-2007 12:59 PM
Thanks Dave.
gtu935 12-14-2007 02:20 PM
engine begins assembly
A long time in the working the engine finally begins assemblyhttp://forums.pelicanparts.com/uploa...1197670836.jpg
gtu935 12-14-2007 02:22 PM
Case work
The case has been dowel pinned, boat tailed and modified for the fitment of a GT3R oil pumphttp://forums.pelicanparts.com/uploa...1197670934.jpg
gtu935 12-14-2007 02:24 PM
GT3R oil pump fitment
Here is a picture of the case rib notched out for the oil pump fitmenthttp://forums.pelicanparts.com/uploa...1197671040.jpg
gtu935 12-14-2007 02:27 PM
above picture
The above opicture shows the rib, Below shows the rib removedhttp://forums.pelicanparts.com/uploa...1197671242.jpg
gtu935 12-14-2007 02:28 PM
pistons
How bout some trick coated pistonshttp://forums.pelicanparts.com/uploa...1197671323.jpg
gtu935 12-14-2007 02:31 PM
crankshaft
The crankshaft is a special one that has reduced rod journal diameters. This was done for a higher rev capability. It was aslo crossed drilled and we machine a special center main bearing to feed the numbers 2 and 5 rod more oil.http://forums.pelicanparts.com/uploa...1197671487.jpg
