Newbe needs help
New to this board and new to Porsche. Need some advice about buying 1999 911. What should I look for? Dealer wants to sell me extended warranty, is that a good idea? Are there companies that anyone has had experince with, endorsed by Porsche folks? Car only has 9300 miles on it and looks like it just came of show room floor. No visible problems, leaks, etc. Runs great. Suggestions? Am I even putting this question in the right place on this board?
Thank you. |
A fellow Pelacanite
You need to go the 996 board.
http://forums.pelicanparts.com/porsche-996-997-991-forum/ Sounds like a great car!
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 06-02-2007 at 01:20 AM.. |
930s rule the wasteland
I work at a dealer ,get the warranty. You dont want to be hanging parts on these cars COD. Just make sure its agood warranty(bumper to bumper) . If I didnt get a warranty on my Dodge I would of been upside down in it.
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Have done a lot of research on warranties and there are tons of them out there. Have not found any good reviews on them either. Any suggestions on which ones are better?
AOLs mainpage just had a write up on this a couple of weeks ago. check that out
The real dreaded problem with the 996 non-turbo cars is the rear main seal of the engine letting go and leaking all your oil out onto the road.
This happens in almost all the normally aspirated 996's. I believe that Porsche has a fix-it kit available with a better main seal that you can have installed at any dealership. Personally, I would not buy the car at all unless the dealership agrees to put the upgraded seal in as soon as you buy the car. Period. Otherwise your new 996 has a better than not chance that it will drop all the engine oil one day, perhaps next week, maybe next year, when you are starting or even driving the car. All dealers are fully aware of this problem, and if they act like they aren't than they are being dishonest. The boxster and cayman suffer the same problem, but not the turbo 996, and none of the 993's. Start a thread about the rear main seal problem on the 996 web forum and see what responses you get. Or do a search. |
