Turbo Tank Drain Plug Torque
Hey Guys,
For all my fellow anal retentive DIY Turbo friends... anyone have a clue on the torque spec for the turbo oil tank drain plug? I have not read in any of the books where anyone actually drains it but I figure someone on here must be at least as crazy as me. Thanks in advance!!!
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
sudo apt-get purge 930
Are you talking about the oil reservoir under the oil filter?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Nope... the little tank under the turbo that uses a 6mm allen wrench. It is an M12 but no one seems to make the exact washer either so I ended up with this relatively large OD but M12 ID aluminum washer and want to make sure I torque it correctly.
A fellow Pelacanite
I don't have that one either and I have the Factory Workshop Manuals.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Yeah, I just got done looking through mine with no luck.
cycling has-been
I would go relatively low, like around 14 ft lbs.
I think the fitting in the tank is brass with a tapered thread. The PO of my car had it overtightened and it was heck to remove. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Crotchety Old Bastard
I don't sweat things like that. Tighten it hand snug and check for leaks then give it an extra tweak. If you drain it with every oil change you'll never have a problem with it sticking shut.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
resident samsquamch
Agreed! You just sort of develop a "feel" for this kinda stuff. I know that sounds like a slam on the original poster, but I don't mean it as such...just use your best judgment and you should be fine. I have found that in most circumstances the "gorilla grip" approach is a bad thing when tightening fasteners on these things (lug nuts not withstanding). Now when you're talking about rod bolts, head studs, case fasteners....then yeah, you gots to bust out a damn fine torque wrench!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
