9dreizig's Avatar
Send a message via AIM to 9dreizig
question for Craig930RS
Craig,
I love your rear bumper so my question is , how did you get the holes in it ? I'm thinking I may do the same to mine ( looks like a really cheap way to eliminate some weight)..
Todd
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-26-2007, 12:30 PM
Macht Schnell
les_garten's Avatar
Originally Posted by 9dreizig View Post
Craig,
Todd
Looks like an awesome way to eliminate some Heat!
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 12-26-2007, 01:33 PM
River Rat
Dave 86 930 Fl's Avatar
I think Todd and Craig need to take this topic offline or move the thread to OT.
Sorry, I couldn't resist the opportunity for some holiday sarcasm.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 12-26-2007, 01:52 PM
9dreizig's Avatar
Craig,, where are you hiding ??
Craig?? Craig?? Craig??
"Todd"
Old 12-27-2007, 09:23 AM
Me like track days
Craig 930 RS's Avatar
Just got back from the inlaws -
PO added the holes to evacuate heat, saving weight - well, not applicable here ;-)
There is a HUGE amount of heat back there, for track use it is almost a necessity.
Maybe this helps others with this idea.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-27-2007, 10:07 AM
9dreizig's Avatar
So any clue as to how it was done ???
"Todd"
Old 12-27-2007, 10:16 AM
Monkey Wrench
Spede's Avatar
Maybe one of these and a lot of WD-40.
Old 12-27-2007, 11:27 AM
Macht Schnell
les_garten's Avatar
Hi Craig,
What diameter are the holes?
Thanx!
Les
Old 12-27-2007, 11:30 AM
Me like track days
Car is offsite so I don't recall. Most certainly done via holesaw and dressed up with a file -
Old 12-27-2007, 01:09 PM
Macht Schnell
les_garten's Avatar
Craig,
A couple questions
1) Is that Bumper Fiberglass
2) If so, where did you get it/
3) How does it mount?
Les
Old 12-27-2007, 01:23 PM
Me like track days
Stock aluminum, mounts reversed to inside, pads removed and mounts covered.
NWIH would I use fiberglass due to heat and reduced protection of a car I've put $$$$$$$$ into -
FWTW and IMO.
Old 12-27-2007, 01:39 PM
Macht Schnell
les_garten's Avatar
FWTW and IMO.
RThanx, Nice Job!
Les
Old 12-27-2007, 03:01 PM
