I've got a few methanol/water injection questions for you turbo carrera guys:
1. On a 3.2 Carrera with the stock Bosch AFM, is it OK to install the injection nozzle in the charge pipe between the turbo and the AFM, such that the vapor will pass through the AFM? 2. Manufacturer's such as Snow Performance state that liquid cooled engines with methanol/water injection can safely run up to 30 psi boost without an intercooler. What would you recommend is the safe limit for an '87 Turbo Carrera with 8.0:1 compression, twin plugs, stock Carrera injectors & methanol/water injection? 3. Are there any Turbo Carrera guys out there using Methanol/Water Injection? |
"Manufacturer's such as Snow Performance state that liquid cooled engines with methanol/water injection can safely run up to 30 psi boost without an intercooler"
NOT |
Hey, this ain't your slutty sister's Subaru! |
Did you install your injector in the throttle body? Or before? Do you have an temperature gauge before and after your IC/injection? |
I am running a CoolingMist system for injection with a single injector at the outlet of the intercooler proximal to the throttle body. I am running a speed-density EFI so I don't have a "barn door" AFM (MAF) to worry about. Ideally, you would like to have an injector for each cylinder or, at least one for each half of the intake plenum. It is a much greater challenge installing injectors on the intake manifold than on the intercooler piping though. I feel I get better atomization and more uniform distribution of the methanol where it is currently located. It has cost me one MAP (manifold absolute pressure) sensor already as my MAP sensor was located in the ECU and was siphoning methanol. I have since moved my MAP sensor into the engine compartment at a level above the throttle body.
My methanol injector system is only a 2-D map based on boost not load. It has the capacity for 3-D mapping but I can't get an analog 0-5V load signal out of my ECU like what comes from your AFM. I have plans to add a hot-wire mass air flow sensor (MAF) in the future to give me the 3-D capability. The other alternative is to go with MS3 control of the meth injection directly but I already have the CoolingMist controller wired in. |
Right now, I'm thinking about going with the Snow Performance Stage 3 Boost Cooler. The software creates a delivery map based on boost and/or injector pulse width. This sounds like a nice upgrade over systems driven solely off of boost, as it gives you more flexibility to dial in the injection and prevent soak. Thoughts? |
Update
Warning: This post is going to full of "Todd said this" and "Todd said that". Forgive me in advance!
I spoke with Todd at Protomotive this afternoon, and, as always, he was very patient and helpful. I asked him what he thought about using Water/Methanol Injection (WMI) w/o an intercooler on a Turbo Carrera, and he was all for it, provided that the system is installed properly and with safeguards. Great! This seems consistent with the current WMI thread in this forum: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/563939-water-methanol-injection.html I next told Todd that I'd like to end up somewhere in the 400-450 HP range and asked him how he'd recommend getting there for my setup. He advised replacing my stock Carrera fuel injectors with 944 Turbo injectors, upgrading my fuel pump if I should ever want to go past 450 HP, as the stock Carrera fuel pump is good up until 475, and reprogramming my ECU. Specifically, he recommended either a GT2 fuel pump or a Bosch 044 pump. Next came music to my ears... he went on to say that with my setup I'd safely be able to run 1.2 BAR boost! That should get me close to 500 HP :D I definitely won't be skimping on the WMI system. Todd has installed a number of WMI systems in the past, including AEM and Aquamist. I'm starting to reach out to guys on this forum who live in my area and have professionally installed these systems. More to come. Todd mentioned that to fine tune my engine once everything is installed that it would be most ideal to provide him with an air/fuel log as well as ignition data, the latter being of lesser importance. Does anyone know what he means by ignition data? Is this something that most dyno tuners would be able to get a read on? I'm also starting to think more about replacing my Carrera heat exchangers with headers. I'll have to figure out how to get around the cumbersome 964 dizzy if I do. Todd mentioned that I should be able to achieve full boost 1000-1200 RPM sooner with a set of decent headers. When I had the turbo on previously, I was hitting full boost around 4k rpm. I'm starting off by looking at the GSF headers. Merv successfully ran them on his setup without an issue, but he's not around for a long term update. I'd be curious to hear your input on this topic. I started a separate thread earlier today to kick it off: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/564067-long-term-review-gsf-headers.html Thanks in advance. |
Hey guys,
Quick update. I started the below thread a few weeks ago to kick around whether I should stick with my Montronic ECU, add a piggyback or go to a full blown aftermarket EMS: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/564876-stick-montronic-go-aftermarket-engine-management-system.html Everyone's input pointed to the convincing benefits of an aftermarket EMS, but the cost of it all made my stomach churn! Fortunately, a fellow Pelican was looking to get out of a complete system that he purchased from Chris Carrol of Turbo Kraft. We were able to strike a deal, so I pulled the trigger on an Electromotive TEC-3R customized by Clewett Engineering. Here are the details of the system: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/529427-fs-engine-management-ecu-electromotive-tec3-efi-porsche-used.html I'm really pumped about this EMS! It's going to solve the issues I've had with my stock AFM and eliminate the cumbersome 964/993 dual head distributor! It will also provide me the capability of running a knock sensor, a 3D map for water/methanol injection (WMI), integrated boost control and of course much more controlled, accurate fuel injection and ignition timing. I'm planning to have Adam Hennessy (BoxxerSix on Pelican) of Rennessy Fabrication do the install and necessary fab work for the EMS, exhaust, intake plumbing & WMI system. I was initially attracted to having Adam work on my car because of his experience with fabrication and WMI installs on 911s. He's been very patient with me and sympathetic to my budget. He's a very meticulous guy and generous with sharing his knowledge. I'm looking forward to working with him. We're tentatively planning the install for late February/March time frame. Adam recommended going with the Aquamist HFS-3 WMI system. We're planning to have the windshield washer reservoir feed the system, and we'll be running one nozzle on each side of the intake plenum. Here are some additional details of the HFS-3: Howerton Engineering Aquamist HFS-3 I've decided to go with a set of headers that fellow Pelican YermanCars used on his beast. The headers were built by AMS of Chicago (www.Amsperformance.com), and Yerman made over 500 HP on the headers. He's selling because he went twin turbos. Here's a link to some pictures: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/506322-fs-3-2-3-3-turbo-headers.html More to come! |
Sounds like a great plan. I like the idea of 2 WMI injectors, I actually have purchased the parts to convert mine to 2 injectors directly into the intake. I would be interested in seeing how he places the injectors in the manifold. I had my intake out recently to convert over to sequential injection and CNP ignition and looked at it for placement options of the injectors. I decided to defer to a later time though as a solution did not "pop" out at me.
Here's when Adam had to say about the placement of the injectors: Quote:
Nice headers.
Me, I would put an air to air intercooler or maybe a water to air intercooler on it if I had to keep the stock deck lid. There has to be a reasion this is done over liquid intercooling by almost everyone. But that is me. Should be a crazy fast car. |
Adam is a good choice to work on your car- I was impressed whe I saw his thread involving a 16G turbo for a Mitsu Evo and how he made an anti surge compressor cover for it by hand (looked like a baby HTA 35R...) The car will be mint when he is done without a doubt.
I've had a number of folks validate the WMI as a substitute for an air to air I/C. Todd from Protomotive said I'd be good to go as long as I stick to 1.2 BAR or less. I think the most significant reason why a lot of folks have steered clear of WMI is the "what is something goes wrong" line of thinking. And that's totally legit! This is one of the reasons why I'm working with Adam, as he has a lot of experience installing these systems with fail-safes. The TEC-3R gives me even more opportunity ensure that it operates correctly (trim boost or ignition if something goes wrong). |
Any idea on where the injectors are going to be placed in the intake specifically? Are they going to weld bungs in or simply drill, tap, and screw? Any links to pics of 964 or 3.2 install photo's?
Good questions. I'll shoot Adam an email and see if he can provide some additional info. |
Thought I'd post some of my engagement pics from last year. I drove the 911 down to South Carolina where my wife was living at the time to get the pics taken, and the photographer incorporated the old p-car :)
http://forums.pelicanparts.com/uploa...1288308519.jpg http://forums.pelicanparts.com/uploa...1288308535.jpg http://forums.pelicanparts.com/uploa...1288308547.jpg |
