Jay Mauney
what plug to use on modified 930?
What plug is the right temp range (or offers the most effiecient use of the added fuel odf the euro cis) for these mods on a 1986 930 turbo
Euro CIS
1.2 bar boost
euro injectors
100 oct av gas (always)
headers
Old 03-06-2008, 12:15 PM
WydRyd's Avatar
You could stick to the OEM W3DPO, but they are a pretty cold plug, so you could even move up to a W4CS plug.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-19-2008, 08:46 PM
Turbo Hooligan
I run denso iridiums, I'll have to look up the model number for you, but I have to run a cold plug to help prevent detonation. I'm one of the few around here that run 1.2 bar.
D-Zug
Old 03-20-2008, 11:09 AM
beepbeep's Avatar
I recomend NGK B8EVX
Thank you for your time,
Old 03-20-2008, 12:01 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Goran, here in the states the EVX (platinum) are discontinued. The replacement is EIX (iridium)for the suffix. I know there is still stock of the platinums scattered, I too used them but in the heat range of 9. The Platinums were also cheaper than the iridiums. If you can still get them they are great plugs. I run BKR9EIX, what I like about this plug, is that it has a 5/8 hex instead of 13/16. This makes it easier to get the socket in the tight confines of the 911. specially if you are running twin plug. Word to the wise you must NOT use those generic sparkplug gap tools on iridium plugs. The ground strap must be bent by itself and not using the electrode as a fulcrum. Rule of thumb is for every 100HP over stock, you run "1" heat range colder.
It changes from time to time.....
Old 03-20-2008, 02:18 PM
Max Sluiter
Flieger's Avatar
Novice question
What does the heat range of a spark plug refer to? How does it relate to detonation?
Thanks for the schooling
Old 03-20-2008, 03:16 PM
beepbeep's Avatar
Didn't know that EVX are discontinued but B8EGV works equally well. I found 9's too cold. Frankly, even 8's get fouled unless you don't give it a boot now and then.
Old 03-20-2008, 03:36 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
It is really cold where you are......... Well atleast to me it is. In Florida (hell) it is hot and well just flat out hot,,,,,,and humid. I have never fouled a 9 but I suspect the colder weather definetly playing a big part in it. Do you guys put your cars away in the winter? And how long are your winters?
Old 03-20-2008, 04:19 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
A givin plug designed for a specific motor will run a steady temp and as long as the mixture is correct, it should last quite a long time. If you have more power being generated the the plug can become too hot and promote detonation. (meaning the plug will be so hot the temp of the plug will ignite the fuel in the cylinder before the coil sends the spark). To control temp or to change the range of the plug the amount of ceramic exposed in the end of the plug determines how hot it will be. If the ceramic is recessed alot in the end of the plug the colder it is, the more exposed the hotter it is. The more power you make the more heat you can generate. so finding the right plug to live in extreme motors is a neccessity. As Goran states you can go to cold and foul the plug. Climate, elevation, and all elements of nature definetly play a part. But if you have normal mods to your 930, only 1 or 2 heat ranges colder would be sufficient.
Old 03-20-2008, 04:31 PM
mppickett's Avatar
The temperature of the spark plug relates to how much heat it conducts out of the combustion chamber. See this page for a great explanation: http://www.ngksparkplugs.com/tech_support/spark_plugs/p2.asp
Different plug manufacturers use different heat range numbers or letters in their designations. Even more confusing, some get colder as they increase and some get hotter as they increase. The hotter they are, the less likely they are to soot up and the more likely they are to cause engine detonation. Your goal is to find a heat range that doesn't soot up in normal driving and doesn't detonate when you are driving at full performance levels.
On my engine (roughly 425 flywheel hp) I use the NGK BKR7EIX plugs which are a couple of steps cooler than the NGK BKR9EIX plugs (CORRECTION, 7s ARE A COUPLE OF STEPS HOTTER THAN 9s IN THE NGKs). I'm dual plugged and it seems to be a reasonable range for my street use with occasional spirited driving. My choice was based on the OEM range of the twin turbos minus one heat range. It wasn't based on extensive trial and error.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 03-20-2008, 04:34 PM
Originally Posted by mppickett View Post
I use the NGK BKR7EIX plugs which are a couple of steps cooler than the NGK BKR9EIX plugs.
I got confused about NGK & Bosch numbering a lot, but I thought for NGK, 7 is hotter than 9?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 03-20-2008, 05:28 PM
Max Sluiter
Flieger's Avatar
Thanks for the info, mppickett and GJF.
Old 03-20-2008, 08:26 PM
beepbeep's Avatar
Yupp. NGK 7's are hotter than 9's. Bosch is other way around.
Porsche started with recomending NGK 8's in turbocharged cars to be on the safe side, which went down to 7's as they noticed that owners weren't driving them hard enough to "unfoul" the plugs.
Old 03-21-2008, 01:18 AM
mppickett's Avatar
You are right. Sorry about the confusion.
Mike
Old 03-22-2008, 03:08 PM
Wo ist die Rennstrecke?
DonE's Avatar
Best advice I've read lately regarding modified engines.
Old 03-22-2008, 07:06 PM
