Help..hesitation issues.
My car came out of winter storage a few weeks ago. Just before I store it I fill the tank and add some Stable. My first 12 mile drive was uneventful. However, my last three drives (all about 15 miles) the car is experiencing intermittent hesitation issues. The car will sputter along until I get the RPMs up and even then it doesn't seem to be running quite right. Then all of a sudden everything seems to run fine. All three times I turned into and headed up my steep driveway the car sputtered, stalled and let out a little pop (backfire). The car has never done this before and I wonder if I may have either gotten some bad gas just before I stored it or maybe the car experienced condensation in the tank while it was stored? I'm at 3/4 tank right now and was wondering if I should continue to drive it until the gas is gone and I can get a fresh tank full or if I should take it into the shop ASAP as bad gas might not be the problem and I might be doing damage to the car.
Old 05-22-2008, 09:58 AM
Max Sluiter
Flieger's Avatar
Sounds like you have a good idea. Drive it some more and see if new fuel helps. Maybe you have gummed up injectors? You could put some injector cleaner in now and in the next tank.
Then there's always the "Italian tune up"
Old 05-22-2008, 10:03 AM
wjfk32's Avatar
Jet Fuel Will Do Wonders....
Old 05-22-2008, 01:24 PM
