No power at #1 fuse
Hi All,
1986 930.
Windows and sun roof don't work but fuse is good.
There is no voltage on hot side of fuse.
Any ideas?
Thanks, Mark
Old 07-09-2010, 02:48 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
yes as I recall the power comes from the "window control unit" in an 86.
it's on my list to fix in my car.. For a really quick fix you can jumper power to the top of that fuse and it should work.
The circuit that goes bad allows the windows to operated after you turn the key off and before you open the door. It's the relay looking unit behind the speedometer as I recall.
T
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 07-09-2010, 03:19 PM
9dreizig's Avatar
Here's my thread this should help you
86 wiring help
"Todd"
Old 07-09-2010, 03:27 PM
Thanks Todd,
Great stuff. I'm off to check pins 7 and 2.
Mark
Old 07-10-2010, 02:47 AM
Turns out it was the relay.
You can open it and find the cold solder joint. ...
Easy fix...no money.
Thanks again for your help
Mark
Old 07-16-2010, 03:33 AM
