9dreizig's Avatar
Send a message via AIM to 9dreizig
86 wiring help
My windows wouldn't work yesterday. I traced it down to no power to the fuse (first one on the fuse block nearest the rear of the car). I can put power to that point and they work fine.
My wiring diagram says that black wire comes from the "power window control unit"..
Anyone know where that unit is ? Looks like a relay box in the diagram
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-01-2010, 01:19 PM
steely's Avatar
This came up before - seems the relay got moved between 86 and 87 - not sure but I think it may be behind the tachometer. My Bentley wasn't clear. I see the schematic reference to the PWCU, but it doesn't give the location or even list it. It does call out the Power Widow relay twice based on year.
As I mentioned, it came up before because someone else had an issue with an 86 and it was setup like an 87 - a little confusing. Maybe Gerry will chime in.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-01-2010, 03:09 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Hi Dan.
Todd,
Here's what I think.
The power window control unit and the power window relay are the same component,
as there is only one relay in the CKT.
Many times when a relay contains any solid state devices, it is designated a "control unit"
Additionally, fuse #1 get's the +12V from the relay.
I would be looking for +12V @ pins 7 & 2.
Pin #7 most probably feeds the CKT, and pin #2 is on the relay armature/contact
which feeds the window switches.
Check all of the above prior to purchasing a new relay, as too often,
P-car owners buy non-refundable unneeded electrical parts.
There is one on eBay. Item #270368115573
Here is the location of the power window relay.
If all of the above fails, pm me.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-01-2010, 03:57 PM
