I agree the wasted spark coils are by far the cheapest way to go. I already had my billet dizzy so I stayed with it. Possibly I will end up going to COP's at a later date. If you have nothing to start and need to decide what to do then I'd go with wasted spark use a hall effect crank trigger and a Ford hall effect cam sensor along with the adapter to mount it to the cam tower. This would definetly the cheapest. If you want to step it up a notch COP's which would not require sparkplug wires. But you would need valve covers to mount the COP's. Hargett Percision Products makes billet valve covers that mounts Ford COP's.
Very sweet, what Program did you use to diagram this out with? |
My problem was me. I had a poorly crimped 12v supply and it finally failed. Fortunately, the LINK tells me which trigger has an error so I was able to tell what was going on immediately.
For what its worth, if I had to do it all again, I probably would have saved a bit more money and gone with some sort of CDI ignition. I currently use wasted spark and it works well, but I think I could get better drivability and torque with CDI. To improve idle and high RPM drivability, I reduced the gap on my plugs from .028 to .023. It smoothed my idle out but I haven't tried the high rpm yet. It's a good thing I have dual plug with this ignition system. |
Nathan,
If you haven't found it yet, here's a pretty good thread on a dual plugged MegaSquirt II installation with some pictures on sensor installation, some sample fuel and ignition maps and lots of Q&A from folks on the forum. http://forums.pelicanparts.com/porsche-911-technical-forum/279322-megasquirt-setup-930-dual-plug-edis.html Noah, great work on the illustration - that will help a lot of folks. I've been running MSII for a couple of years and have been very happy with it. Good luck! |
Thanks Guys!
I have to admit, I forgot to search the 911 forum... |
The knock sensing module I am still working with, I think it should be fine but I might need to add a fuse on the +12V power line off the main relay. Also, there is a chance that I will have to add some sort of signal conditioner to dampen out noise that is from normal operations. I see no reason why we can not have knock sensing on our engines. Quote:
http://forums.pelicanparts.com/porsche-911-technical-forum/173248-twin-plug-goodness-look-what-i-made-weekend.html |
| All times are GMT -8. The time now is 10:13 PM. |
