CIS Injector Torque Value
I went through the search function, my manual and a google and don't seem to be smart enough to find the torque value for the CIS injector to intake spacer block.
Anyone know the proper torque value? I installed new copper gaskets so I want to make sure I get the injector seated and the washer crushed to the correct value. Thanks in advance!!!
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
I am going with 10 ft lbs at this point unless someone has a better plan???
A fellow Pelacanite
Is it not in the SC manual?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
A fellow Pelacanite
It is in the 930 manual. 5lbs ft.
what page Nathan? I looked this morning and could not find it.
Dan 88 930 blk/gry |
A fellow Pelacanite
10-06 states Injection Valve 5ft.lb
25-1 confirms the name of the part and the quantity on the car.
Hmm... section 10 in my manual is all about removing the engine and transmission. Regardless, I will trust your research and stick to the 10ft/lbs that I torqued them to and call it a day. Thanks for following up!!!
A fellow Pelacanite
No problem. 5lbs doesn't seem a lot but then again those blocks are not very strong IMO.
Injector Torque Specification
Nathan is correct:
A fellow Pelacanite
Yep, that's 10-06.
I just had this exact question again 3 years later and found this thread using the search function. LOL!!! I was about to post this question again. Hahahahaha
