how to set timing
hi i just got done building my first 930 motor(stroker knife edge crank c2 p/c boattail cases 40 mm intake ports balanced on and on) but how do i set the ignition
bump
if you are talking about the dizzy, just set it statically. To do that, make sure the engine is at TDC (verify by checking cylinder #1). Then point the dizzy rotor to the notch on the dizzy casing (will be a small line that looks like someone took a chisel to the metal casing). This where spark plug #1 will go, then follow firing order listed on the engine bay sticker. Once you start her up, use a timing light to make final adjustments.
If you are talking about cam timing. do a search for my name, and cam timing. We covered it very extensivly in a thread.
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
