Fabspeed Headers - Anyone running them?
Was visiting Fabspeed's web site yesterday and saw they now are making headers. Has anyone seen them or bought them?
Not I, but I did see a post several weeks ago on Rennlist about them. They look promising...
If I were buying headers, I'd wait for some longer term results from other early adopters....
failed headers make a MESS out of a turbo. |
I have their Muffler and their quality is second to none IMHO. I'll have to look over their headers...
Some manufacturer needs to make headers from 409 SS instead the 304 SS everyone is so fond of. |
I'm sure I'll be flamed for being a cheap skate and taking the Chinese child labor approach, but my OBX are T321 stainless, fit perfect, cost $499 (including shipping) and are still holding up.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/345731-b-b-headers-got-god-d-mn-hole.html Perhaps I got lucky... |
FWIW, if you're looking to outlive the stockers, the SSI solution that RarlyL8 and M&K have worked out, appears to be the way to go.
Well, your OBXs weren't exactly a perfect fit, but they are only $500.
I plan to do a second generation SSI setup soon which should resolve the remaining fitment issues for the different cars. I simply don't accept the alignment problems caused when combining aftermarket headers and turbos. My version of "bolt-on" apparently is not the same as others. Because of that I have turned down several sales. Everything is made in China now. The QC is not in place and the metal is often not as represented. Chinese spec 304 is not the same as US spec 304. You will see failures in the years to come. At $500 a short life may be acceptable. At $2000+ it is not. . |
Im with Les, I have a Fabspeed muffler and happy with it. I will be checking out their headers for the rebuild in the fall. $2500 is certainly easier to swallow than $5-7K for Mode headers.
| All times are GMT -8. The time now is 06:49 AM. |
