Weight savings in a 1991 turbo
I have a 1991 911 turbo, and was wondering what people do to these cars to drop weight. I have a fiberglass deck and wing, but would prefer to stay away from glass body panels. Other than that let me hear what you have done! Weights would be great as well. Lots of information on the older cars, but have not seen much on mine.
The same things should work on the 965. Remove sound insulation, ac system, stereo system, carpet in cabin and trunk. Replace heavy electric seats with lightweight racing seats, replace battery with a Braille battery...
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Fit shorter performance Headers/exhaust
Remove air injection/pump etc (if this is possible in your country with emmision regs etc)
SP Autobahn www.spautobahn.co.uk Porsche inspector for Peter Morgan UK http://www.porscheinspections.com/ "92" 964 turbo,Modified and recently rebuilt using all ARP hardware.. Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj. |
Ha, ha.ha, ha... obviously you haven't seen his motor! That stuffs' long gone!!
RGruppe #180 So many cars.. so little time!! |
The stock dual mass flywheel is a good one to reduce weight. Of course you need a different ignition to run one on a c-2 turbo...
Sounds like that may be long gone too... You could always graft on a non-sunroof roof panel, if you have a sunroof... |
By the way, all DEKA batterys are much stronger than odyessy batteries in the same size range and also much cheaper. http://forums.vwvortex.com/zerothread?id=2353060 I run the "Big Crank" Deka in my car, I got a 17 lbs battery with as much juice as the 26 pound odyssey. It is a little confusing, but the Braille battery website tells you the real output of the Deka batteries in question, and the generic cheaper websites like Big Crank under-report the output by about 50%. The bargain DEKA batteries are all the same output as the Braille/DEKA. Same exact thing. Last edited by DDDD; 08-08-2008 at 12:38 PM.. |
Cynical Misanthrope
No kidding on the Dual-Mass!!! I just pulled mine off the longblock the other day... 'bout broke the garage floor when it came off!!!
It sure isn't going back on. Bring on the gear-chatter, I hate slow-revving engines.
X-1, AFM744, Jon, '92 C2 Turbo JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending... Where my misspent time and money is currently going. |
Cynical Misanthrope
In more general comment to the thread, I'm not going to try to strip my car to a track axe, but I am going to try to remove the heaviest stuff farthest from its polar moment of inertia. In engrish that's the stuff furthest from the middle. The PC925 I put in my last car is still going strong 4yrs later so I'm inclined towards that. Definitely a LWFW. The above-mentioned removal of smog. I already have a full B&B.
Here is my list of weight savings.
Spare tire 35 lbs lower door pockets 6 lbs tool kit/compressor/floor mats 10 lbs zork pipe weighs 2 pounds total/replaces muffler system B+B headers weigh maybe 15 lbs less than stock. Back seat tops 15 lbs. Air conditioning 75 lbs. Full size battery 35 lbs Deka replacement battery 17 lbs rear bumper with shocks and pads 45 lbs front bumper with no shocks or lights 25 lbs Fog lights/front bumper shocks/washer fluid tank and system 34 lbs (with no fluid in the tank!) rear speaker deck 12 lbs (replace with carpeting) rear insulation behind seat, top piece 8 lbs, bottom piece 17 lbs rubber tray tail unit 28 pounds rear engine lid 10 lbs modern C2 diverter valve set up from intercooler subtracts about 8 or ten pounds I know that doesn't all apply to your situation, and came off an 1976 930, but it is good information to get out there in cyberspace. Last edited by DDDD; 08-09-2008 at 06:05 PM.. |
I am not real big on the small battery. I have ran them in my cobra, and they just simply dont have much reserve in them. Ya smog is gone in my car lol.
The AC system weighs 75 pounds?
Rear condensor and bracket
front condensor and bracket compressor unit with clutch which also is parasitic drag on your engine pulley system front blower fan 20' worth of hoses undercar grille to protect aforementioned front condensor Evaporator unit in smuggler's box I think the freon even weighs several pounds, not that it ever stayed in my system for more than a month... The sad part is I didn't even remove the fan in the smuggler box or the blower under the dash because I use that loop for air circulation in the cabin. Even a single condensor system probably weighs 60 lbs or more, especially if you remove the things I didn't. Out of me and two other guys who did this locally, we all got over 60lbs from AC removal. Last edited by DDDD; 08-09-2008 at 06:06 PM.. |
I just did a quick charge on my little DEKA today since the car has been sitting for like three months.
With a 1.5 amp charger, it juiced up in about four hours to full capacity. If I drive the car every couple weeks, I don't bother charging it. |
Metal Guru
I'm going after the low hanging fruit but a stripped out 965 has no appeal to me:
* Rarlyl8 muffler in place of the cat and stock muffler (someday) saves approx. 50 lb. Currently I have a cat bypass installed so I'm halfway there. * No Air pump and associated plumbing saves 20 Lb. * Drain 7.5 litre reservoir 17 lb. * Westco battery in place of stock battery 30 Lb. * No spare or tools 50 lb. So now I'll save approximately 170 lb. and the car still has the stock appearance.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Dang didnt know the AC system weighed that much. What is the 7.5 reservoir? I dont want to gut my car, but I am going to shed a few pounds. Not enough hp to push it around
I have a burns 4 inch muffler on mine. That thing weighs nothing!
Metal Guru
The A/C in my SC was 70 lb but it had hoses running everywhere and two condensers.
I think I read on Rennlist that the 964/965 A/C is around 55 - 60 lb. I'd remove my radio before I'd remove my A/C.
I kept the tunes, just removed the whole rear speaker deck and will put down some black carpeting instead. The radio is just as loud and clear thru the door speakers, IMO. |
Cheers, Jeff |
Cynical Misanthrope
Jeff, is the Patrick the only LWFW that bolts on to our car?
