vmb vmb is offline
vmb's Avatar
need CV assembly help
Trying to reinstall my axles, and putting these gaskets on it just doesn't seem right. It seems as though they would be a better fit between the CV and the inside boot flange, not between the CV and the tranny. This picture is where the Pelican diagram shows it should go, but I need to double check here. For the CV/boot flange there was RLV from the PO, so that's what I was planning to do too, but this gasket seems to be a perfect fit there.
thanks for any help.
Vic
'79 930
'97 Miata M edition
missing my Tony//Kart 125cc shifterkart
Old 10-11-2008, 10:20 AM
rsrmike's Avatar
that is correct, the boot normally has one too but it's usually stuck to the boot flange quite well...
Professional Overcomplicator
Old 10-11-2008, 10:23 AM
rsrmike's Avatar
BTW, what kind of grease is that?
It looks like red wheel bearing grease? hopefully I'm wrong
Your joints will most likely protest soon if you aren't using moly grease
I've used Redline axle grease once but I seem to remember it still had some grey color from the molybdenum in it?
Old 10-11-2008, 03:35 PM
A fellow Pelacanite
NathanUK's Avatar
Those gaskets usually have a peel off backign so they stick on.
I always reuse them with no problems providing they dont split or break.
The grease I use is black.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-11-2008, 05:27 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
I don't use the gaskets as they always break and I never have any leakage,, actually I seem to drop my engine enough that's I'd go broke buying gaskets LOL
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-11-2008, 06:17 PM
full quack's Avatar
Send a message via Yahoo to full quack
+1 big time on the MOLY. grease!!
Old 10-11-2008, 07:33 PM
vmb vmb is offline
vmb's Avatar
Well, it's Mobil 1 synthetic grease. Not good enough? I only packed that one CV, so not a big deal to get different grease for the other three. But, if the Mobil 1 is fine, I'll use the tub that I have.
Vic
'79 930
'97 Miata M edition
Old 10-11-2008, 07:41 PM
vmb vmb is offline
vmb's Avatar
OK, I admit I screwed up here. That's what I get for going to Pep Boys for lube. I didn't see anything that said "CV" specifically, so I figured this would be a good choice. I am very thankful you guys pointed it out before any damage was actually done.
Vic
'79 930
'97 Miata M edition
Old 10-11-2008, 08:13 PM
rsrmike's Avatar
look on the label and see if it says MOS2 anywhere, I think it's molybdenum disulphide.
If not, your better of w/ a lesser name brand that has it
Old 10-11-2008, 08:15 PM
rsrmike's Avatar
pep boys should have some kinda moly...
Old 10-11-2008, 08:16 PM
A930Rocket's Avatar
What year is your car? The earlier cars used the gaskets. My 87 does not.
Old 10-11-2008, 09:48 PM
Quick question: Is my car supposed to have these? It seems like there are 2 styles of 930 CV.
I think as an 84 mine has the earlier type.
I just removed one of my CVs yesterday and I dont have any gaskets Nor do I have any of those end caps that seal in the grease for assembly
07 Exige S
Old 06-30-2014, 09:04 AM
