Width of 930 flywheel seal?
Can someone please tell me what the width of the 930 flywheel seal is?
Part number 99911342641 In Wayne's book it says 90x110mm but no width. Thanks!
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
I'm going to guess it's 90mm ID and 110mm OD, making it 10mm wide.
If you mean 110-90 that's 20mm but I don't mean that direction
I was thinking 20mm /2 = 10mm.
You want the depth? |
Certified User
I just measured one I removed recently and it is 12mm wide.
ID = 90mm, OD = 110mm (but you already knew that!).
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Thanks Billjam...that's what I was looking for. I want to try and get one from a company like Chicago-Rawhide. I'm told they make double spring seals and I wanted to be able to spec the width...and order one before I take things apart.
Thanks again!
