What's My Options Here? Oil Cooler Line
I noticed some bone head crushed my oil cooler return line. Should I spend close to $500 for a new line? Or is it possible to have one made out of braided line? Thanks
My line
New line
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 05:19 AM
Garage Queen
PorscheGAL's Avatar
To replace mine on my 911, I purchased Elephant Racing's Finned Oil Return Line. They cost $355 a line which is a little less than the conventional solid line.
Our host sells them for ER.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 08-11-2012, 06:07 AM
Funny I just sent off an email to them. Do you know what size wrench I'll need? Thanks
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 06:11 AM
This is an interesting crushed oil line thread. Looked like it worked and cost next to nothing.
Fixed my Crushed Oil line for $5 and a beer.
Old 08-11-2012, 06:36 AM
Garage Queen
PorscheGAL's Avatar
Not yet. They ( I needed both a send and return line) are to be delivered Monday and then I can check the wrench size needed.
Stephanie
Old 08-11-2012, 06:42 AM
Thanks I saw that but mine is damage at the U so I don't think that method would work.
No problem Porsche GAL.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 06:54 AM
It may be 36mm, you can measure it with calipers. I used a big $10 harbor freight crescent wrench on mine and it did the job.
Luckily being a garaged southern car all it's life before I got it they weren't corroded on and unscrewed easily.
Put some anti seize or grease on the threads when reinstalling them so the aluminum threads on the thermostat don't gall together with the steel threads on the pipe fitting and it can be removed again easily.
Alumninum threads like on the thermostat suck and have to be lubricated with something that sticks around.
Old 08-11-2012, 06:59 AM
Thanks...So I don't need any thread sealant so they wont leak? Also Would I need to drain the oil to replace that line?
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 07:05 AM
beancounter
jwasbury's Avatar
My friend used this method successfully. Why not give it a shot? Worst case scenario it doesn't work and you go ahead with replacement. If it does work, you save $400.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 08-11-2012, 07:20 AM
Oh by all means I will. I'm first going to remove the line and see what I can do with it before ordering a new one.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 07:26 AM
"So I don't need any thread sealant so they wont leak? Also Would I need to drain the oil to replace that line?"
No, don't use thread sealent there because those threads have absolutely nothing to do with making the oil seal. It's a metal to metal compression fitting that gets pressed together tight and seals as you tighten the big nut.
If thats confusing then google compression fittings to learn how they work. Don't overtighten them either because that will crease/deform and ruin the rounded sealing surface on the end of the oil line and the male aluminum threads on the thermostat will not like it.
Only time you use thread sealent is when the threads are making the seal like tapered pipe threads.
Old 08-11-2012, 07:57 AM
Perfect, thanks for the info.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 08:00 AM
You should do a little research on removing the old ones. On many occasions they don't come off cleanly and ruin the fittings used to attach them.
There are plenty of threads about it in the 911 tech forum.
1987 GP White 930
1977 Ford Bronco
Old 08-11-2012, 08:31 AM
I've gone native
Tt surgeon's Avatar
I would just do a new line. I think the heating/pressurized air trick might create a weak point from metal fatigue.
The finned ER lines work great.
Old 08-11-2012, 11:09 AM
I did, it states to heat the fittings before trying to remove them. I think my car spent most of its life in the garage.
Tt surgeon, I'll take a look at it once I get it off and go from there.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-11-2012, 01:45 PM
Do I need to drain the oil before I try to remove the line? Thanks
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-15-2012, 11:26 AM
